Couple Questions
Old Mar 25, 2010 | 07:50 AM
beachbummer0069's Avatar
beachbummer0069
Question Couple Questions
I'm selling my chrome front bumper off my truck. Just the bumper itself with out the brackets. My buddy has an 07 2500 will the front bumper work on his truck. Will his brackets line with holes on the bumper to mount tthe bumper to the truck. Also, I tried to install my add a leaf yesterday and ran into a problem. I removed both rear tires, I removed both shocks and loosen alll 4 u bolts. I had the frame of the truck supported on jack stands and a floor jack under the rear. I removed one side of the u bolts and went to lower the axle and the leafs do not separate for the axle. The instructions told me to lower the axle and leafs and the axle should separate. Does anybody know what I could have done wrong or if I missing a step. lol
Old Mar 25, 2010 | 07:56 AM
RedTruck-VA's Avatar
RedTruck-VA
My guess is the bolt that holds the spring pack together is stuck to the axle perch. Did you smack it with a hammer to knock it loose?
Old Mar 25, 2010 | 08:29 AM
beachbummer0069
Nope I was not going to get too in depth because I had some where to be last night. But I plan on trying to do it again this weekend
Old Mar 25, 2010 | 10:48 AM
korby05's Avatar
korby05
From what I understand b/c I'm lookin for a new front bumper is that all you have to do is just switch the brackets from the 1500 to the 2500 or vise versa... If it doesn't work out..I still need a bumper...
Old Mar 25, 2010 | 11:02 AM
RubberFrog's Avatar
RubberFrog
The bumper will bolt right up.
What do you mean you "removed one side of the ubolts?" Take the ubolts off and the leafs will separate from the axle. You may need to lift the frame higher.
Old Mar 25, 2010 | 11:13 AM
beachbummer0069
the instructions say to do one side at a time. I did remove the u bolts fully out of the right side and went to lower the axle n leafs just came down with the axle
Old Mar 25, 2010 | 11:17 AM
RubberFrog's Avatar
RubberFrog
Gotcha, I thought you only removed one nut off each ubolt. lol
You just need to jack up the frame more. It's amazing how much arch the springs have when unloaded.
Old Mar 25, 2010 | 11:36 AM
beachbummer0069
got yea ill try to do it again this weekend when i have some time to do it
Thanks for the help
