5.7 HEMI Engine BLOWN????
Old Mar 25, 2010 | 01:31 PM
FireFighter's Avatar
FireFighter
From: The old famed Gen3 Broken Valve Spring Thread - https://dodgeforum.com/forum/3rd-gen-ram-tech/237316
10-4. Thanks guys
Old Mar 25, 2010 | 01:33 PM
HammerZ71's Avatar
HammerZ71
Originally Posted by FireFighter
Not hijacking thread but, I didn't like seeing #B, as I use 87 primarily due to the ton of driving that I do and the cost. What problems have come up due to this?
I've been kinda "unofficially" compiling data on this and in almost every case where a cylinder failed and I'm talking like died dead failed, the owner has either up front stated that they mainly use 87 octane gas or has later admitted it. A lot of valvetrain related problems been reported by 87 octane users, right down to blown pistons.
Will you have a catastrophic engine failure if you only use 87 octane? Maybe not, but I'm 100% convinced your odds are considerably higher...
Old Mar 25, 2010 | 01:36 PM
dirtydog's Avatar
dirtydog
Moderate User
I agree with everyone else that your engine is not toast and there is some other issue ging on. If your engine was locked and wouldn't turn over, then your tires would have been screeching from being locked up. The transmission is run off the rotation of the engine. No rotation when in drive means you go nowhere.
Could be a simple fix like the pcm/ecu or even an ignition switch.
Any engine that I have seen apart that had been run off 87oct has had tons of pre-detonation gouges out of the piston which makes for lots of hotspots and then cause further problems. Even more so if you continue to run low grade gas.
Old Mar 25, 2010 | 03:24 PM
abarmby's Avatar
abarmby
Recently, FireFighter unfortunately had a broken spring.
Would 87 octane cause his problems?
Al.
Old Mar 25, 2010 | 03:57 PM
HouseApe's Avatar
HouseApe
Um 87 octane is fine with the 5.7. under normal conditions. If your towing or hauling heavy loads then 89 would be better. The knock sensor and computer will compensate for the lower octane by retarding the timing = lower power output and lower fuel economy
*Edit - Also if your a led foot or have a high mileage with lots of carbon build up then the higher octane that is recommended will be better.
The 5.7L engine is designed to meet all
emissions regulations and provide satisfactory
fuel economy and performance when
using high quality unleaded gasoline having
an octane range of 87 to 89. The manufacturer
recommends the use of 89 octane for optimum performance.The routine use
of premium gasoline is not recommended. The use of
premium gasoline will provide no benefit over high
quality regular and mid-grade gasolines, and in some
circumstances may result in poorer performance.
Light spark knock at low engine speeds is not harmful to
your engine. However, continued heavy spark knock at
high speeds can cause damage and immediate service is
required.
Old Mar 25, 2010 | 05:32 PM
FireFighter
Wow. Ok, 89 upgrade it is. Great, at another .17 per gallon, but that's cheaper than a burned cylinder. I'm not towing, etc. Just mainly alot of miles per week, normal conditions.
Old Mar 25, 2010 | 05:36 PM
AF_HEMI's Avatar
AF_HEMI
at least you're not in the UK. Al, what do you pay for petrol over there? lol
...talk about a thread jack
Old Mar 25, 2010 | 05:38 PM
HammerZ71's Avatar
HammerZ71
Um, the manual may say that, but unless you've seen the inside of a few Hemi's with cylinder damage and have verified that in EVERY case the owner ran 87 octane exlcusively, then you go right ahead and believe everything Chrysler tells you.
They also swear they've never seen a retaining clip fail in a Chrysler LSD also...
And FireFighter, I've done the math, although it's scewed because I did it while running a superchips tuner, but running 93 octane fuel with the performance tune yielded the best cost per mile driven of any of the scenarios I tested, 87 on 87 tune, 89 on stock, 89 on 87 tune and so on. So you may pay more per fill-up getting 89 octane, but your mpgs will probably off-set the cost difference...
Old Mar 25, 2010 | 06:21 PM
HouseApe's Avatar
HouseApe
Not debating what you have seen but I can tell you that it has allot to do with a) driving style b) operating conditions c) quality of fuel d) mechanical condition of components such as knock sensor, egr, carbon build up, spark plugs etc. than just the 87 octane fuel itself.
I run 87 just putting around town and 89 when towing.
Old Mar 25, 2010 | 06:40 PM
hemi525hp's Avatar
hemi525hp
my 04 hemi crapped out and it was the number three piston and an exhaust valve. i fixed it myself and built it a "lil"
