wideband/aeroforce need help and advice
Old Mar 26, 2010 | 07:52 PM
Kamel87's Avatar
Kamel87
Default wideband/aeroforce need help and advice
ive been wanted to get a a/f gauge and i started researching the idea. turns out my cousin has a lc-1 that he said he would sell to me cheap. when i searched the forums the aeroforce interceptor caught my eye. can i use that gauge with the lc-1 or do i have to buy everything from aeroforce. also for those who have the interceptor i saw u can buy it from there website for 250 is that just for the gauge and do i need extra sensors for trans temp coolant temp etc....
thanks for you help and advice
pierre
Old Mar 26, 2010 | 07:56 PM
JoeHemi's Avatar
JoeHemi
I dont have the wideband, not sure on that. But no, once you buy the gauge it plugs into your OBDII port and reads all that info so no need for additional sensors/gauges to read trans, coolant, etc.
Old Mar 26, 2010 | 08:33 PM
truckin151's Avatar
truckin151
As long as the additional sensor is a 0.5v (or 5v not sure without going to the site and checking) it can run it, although the aeroforce uses a nice bosch wideband kit (does not come with it though) but other than that you dont need any other senors as it'll read everything off your OBDII port.
Old Mar 26, 2010 | 09:13 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You can use the LC1 with the Aeroforce but you may want to look at the OT-1 on Innovates site to go with the LC-1 as that would allow you to datalog and go AFR v/s RPM and be more cheap all in the same time.
