issues removing clutch fan need help
Old Mar 27, 2010 | 02:16 PM
beachbummer0069's Avatar
beachbummer0069
yeah i m turning it to the left (passenger side) im going to put some P B blaster on it and let it sit hopefully it will break loose. Me beating on this will not damage the water pump will it?
FireFighter's Avatar
FireFighter
From: The old famed Gen3 Broken Valve Spring Thread - https://dodgeforum.com/forum/3rd-gen-ram-tech/237316
Originally Posted by SMKNRAM
I used a pc of wood that ran to the ground with a bolt through it and it is reverse threads
Lefty loosey righty tighty on my '03 5.7L
Old Mar 27, 2010 | 02:20 PM
FireFighter
No, your WP will be fine, just be careful not to let any long bolts, etc jam into it. I think the loosening agent will help. Good luck
Old Mar 27, 2010 | 02:23 PM
SMKNRAM's Avatar
SMKNRAM
persistence pays off!! it will come off. the bolt needs to fit tight up against the pulley. and not have much play in it
Old Mar 27, 2010 | 02:35 PM
beachbummer0069
FINALLLLYYY, I broke it loose. The clutch fan is off lol. Thank yall for your help
Old Mar 27, 2010 | 03:01 PM
FireFighter
You're welcome. So how did you finally get it off? x2 on the bolt needing to be tight and no play.
Old Mar 27, 2010 | 03:09 PM
beachbummer0069
well nxt go around the board broke so i just used a bigger size bolt and board and didnt put a nut on the back of the bolt this time and just kept hitting it and then realize it was starting to unscrew lol
Old Mar 27, 2010 | 03:17 PM
FireFighter
cool....good deal
Old Mar 27, 2010 | 04:53 PM
MikeHTally's Avatar
MikeHTally
A Carlisle spanner will do it for you. Mine was a b!tch to remove as well.
Old Mar 27, 2010 | 04:55 PM
beachbummer0069
Got it all done and now i think the flexa lite adjustable temp control switch i bought is bad. The fan will not come on at all. The fan does work i checked.
