ABS and Brake light Issues
Old Mar 30, 2010 | 03:09 PM
boopadoopa's Avatar
boopadoopa
Wheres the speed sensor on the rear axle? Top of the punkin?
Old Mar 30, 2010 | 05:01 PM
roamrocker's Avatar
roamrocker
This is all greek to me too. I just got this truck about 2 months ago. I am really leaning twards it being the brake switch on the pedal. Maybe ill grab one after work and try it out!
Old Mar 30, 2010 | 05:27 PM
mcgoo89's Avatar
mcgoo89
Yah, on top of the pumpkin..
Old Mar 30, 2010 | 07:19 PM
roamrocker's Avatar
roamrocker
Local Checker has the switch for $11. Im going to grab it on the way home then ill let ya know how it works!!
Old Mar 30, 2010 | 07:35 PM
cwboyjohnny24's Avatar
cwboyjohnny24
Look at the speed sensor. Here's a pic of it. From everything I've gotten from people it's either got water in it, or it's bad. Yeah, it's on top of the rear diff.
speedsensor.jpg?t=1269992075
Old Mar 30, 2010 | 09:27 PM
roamrocker's Avatar
roamrocker
Well as of now the switch cleared up my issue. At least the light part. Well see if i get the warning lights tomorrow when i drive it.
Old Mar 31, 2010 | 08:14 AM
boopadoopa's Avatar
boopadoopa
Roamrocker.. Let me know Mine was flashing all the way to work this morning ...stupid bells.. I called Advanced auto and they dont have a listing for the speed sensor and said ill have to go to the dealer??? I had the same crap with my Dakota had to get parts from the dealer only at prices inflated by 400% So If I can change the brake switch for like under 20 bucks Ill do that first before paying a weeks pay at the dealer for a 40 dollar speed sensor.
Old Mar 31, 2010 | 08:23 AM
boopadoopa's Avatar
boopadoopa
Ok thats was painless Called Dodge and the speed sensor is only $17 dollars?? Wow something cheap at a dealership??? Ill get it and try it later tonight and will let you know if that takes care of the issue.
Old Mar 31, 2010 | 08:37 AM
roamrocker's Avatar
roamrocker
Sounds good, The dash warning lights wouldnt always come on either. Easiest was i knew if i was having a problem was to try the cruise control. Im bout to head to work, ill post up if its gone or not.
Old Mar 31, 2010 | 09:15 AM
roamrocker's Avatar
roamrocker
OK, i got no warning lights but the cruise control STILL didnt work. I did notice that if i used my foot to pull up on the brake pedal then the cruise would work until i left off. When i pulled up on it it seemed like a tiny amount but it must just be enough. Im going to put something between the light switch and the tab on the pedal to push that button in a little more and that should fix my problem.
