Muffler Shop Guy said NO on the headers
Old Mar 31, 2010 | 09:42 AM
  #31
truckin151's Avatar
truckin151
Originally Posted by haulinhemi06
so long as your headers retain your cats, they can even be magnaflow hi flow, youre set on emissions and visual. im not sure about youre states codes, but you shouldnt have any problems.
however, i dont know a longtube header on the market that allows you to retain that factory position. maybe there is. on any emissions-controlled vehicle today, its illegal to move the cats from the factory position. its also illegal to tamper with the egr valve.
with longtubes and relocated cats, youd pass emissions but not visual. if you got caught on the street with an illegal exhaust setup youd probably get a nice hefty fine. check your states laws before spending the money to put headers on. otherwise, setting up longtubes would be a waste, theyd make you get a different setup.
you probably wont get caught to be honest. the only reason a cop might check would be noise level.
NO he wont be safe as far as a visual inspection goes, even if he retains the stock cats, if he moves them from the factory location and they do a visual check he's SOL. There is no way to have long tubes and have a factory cat location as the length of the longtubes moves everything back 6-8" more or less. The only kit that I am aware of that claims to be long tubes are dynatechs I beleve (may be wrong on the brand) and they will sell you the full kit (headers, cats, Y,) and they claim that you keep the stock cat location but they also want $1200 for the kit.
Now what I did with my truck was install the headers in my garage, and then I took it over to a friends shop who has a lift and we fab'd up the rest of the piping to add in the stock cats and litterally made it look like that was how it was suppose to be installed stock. Everything from the way the cats are installed to the way the wiring was done looks stock. I have no CEL's and everything is running fine.
If you are worried about passing emissions, first check your local laws and see how they do an emissions test, if they only do the OBDII test your set, if they do a full visual check or you just dont feel comfortable installing LT's sell them and pick your self up some CARB rated shorties or mids and you'll be fine.
Old Mar 31, 2010 | 09:56 AM
  #32
haulinhemi06's Avatar
haulinhemi06
i meant to put shorties would keep the factory position. yeah with long tubes theres no way.
and i saw that dynateach kit, seemed like a good idea but i wasnt about to pay 1200 buck plus install.
Old Mar 31, 2010 | 10:29 AM
  #33
weedahoe's Avatar
weedahoe
Hall of Fame Member
Man I am SO glad we dont have that BS down here
Old Mar 31, 2010 | 12:17 PM
  #34
truckin151's Avatar
truckin151
We just have theOBDII test here for newer vehicles. I get to test this this summer Yay!!
Old Mar 31, 2010 | 12:33 PM
  #35
nim81's Avatar
nim81
here it doesnt matter where your cats are at, as long as they are there.
Old Mar 31, 2010 | 12:38 PM
  #36
RubberFrog's Avatar
RubberFrog
In my county, you can't replace a cat unless an emissions center certifies that the old one has gone bad.
Old Mar 31, 2010 | 12:40 PM
  #37
nim81's Avatar
nim81
strict strict strick. i cant believe they make up rules like that. completely ridicoulus
Old Mar 31, 2010 | 01:36 PM
  #38
HammerZ71's Avatar
HammerZ71
I'm in good old Georgia, no tests whatsoever. My cats are back about a foot give or take, they are the stock ones and if you don't specifically know where they are supposed to be, they look perfectly normal. I even matched the wire colors when I extended them, but you will see about an inch and a half of shrink tubing where I soldered them...
Old Mar 31, 2010 | 02:46 PM
  #39
truckin151's Avatar
truckin151
Everything about mine look stock. Which brings up another question. How do they know exactly where 'stock' is? I've looked and cant find any markers as to a specific location.
Old Mar 31, 2010 | 03:12 PM
  #40
RubberFrog's Avatar
RubberFrog
Usually the welds around the cat gives it away. The factory welds are robotic, the shop welds aren't always so clean. Remember the herpes muffler? That guy wouldn't fool anybody if that was a cat!
