Need assistance!! front door soeakers
Ditto. Shiloh, where did you get your info from??...lol
Regardless of what type of sub you plan on running...15w won't be nearly enough power to even make them sound like a sub, plus you really need a dedicated ouput so you can adjust the frequency repsonse properly.
The Cleansweep will enhance the sound dramatically, but if your tight on cash, I'd say just pick up an aftermarket deck and that will solve all your problems
The clean sweep is a great route to go but for the price you may as well get an aftermarket deck and amp.
If I remember Rockford makes one as well that's a lil more cost effective called the 3sixty.2.
There is also the Alpine pxe-h650.
They all have their ups and downs such as you will have to mount their volume know which replace the use of the factory ****/steering wheel controls. Also some have built in eq's and others do not.
thats what I want too avoid kicker.comhad a system with an amp and a woofer getting the in to the amp from the left side front speaker guess I could go that route. It's www.kicker.com/mopar option #1
thanks silvr but my hu is a satelite system and i'm not good at dash work I'll be the first to admit If that happens rico and his merry hi-fi unit would be making an appearance. i aint got the bucks for that and like I said wanna keep it as is. thanks anyways...btw pm a price what kind is it...wifey has a 2010 journey all wheel drive can you say guinnea pig lol
