Power wire
Old Mar 31, 2010 | 08:38 PM
wyseguy77's Avatar
wyseguy77
I'll make you one for $15 lol
Old Mar 31, 2010 | 08:57 PM
RedTruck-VA's Avatar
RedTruck-VA
Originally Posted by lxman1
It will run a little richer (more fuel) and have a little more timing. It does not put the thing into open loop. It just fools the PCM into thinking the incoming air is about 20 degrees cooler. It is basically a $65 2 buck 4.7K ohm resistor.
Hate to disagree, but the manual states otherwise.
This is an Open Loop mode. During engine warmup,
the PCM receives inputs from:
² Battery voltage
² Crankshaft position sensor
² Engine coolant temperature sensor
² Intake manifold air temperature sensor
² Manifold absolute pressure (MAP) sensor
² Throttle position sensor (TPS)
² Camshaft position sensor signal
² Park/neutral switch (gear indicator signal—auto.
trans. only)
² Air conditioning select signal (if equipped)
² Air conditioning request signal (if equipped)
Based on these inputs the following occurs:
² Voltage is applied to the fuel injectors with the
ASD relay via the PCM. The PCM will then control
the injection sequence and injector pulse width by
turning the ground circuit to each individual injector
on and off.
² The PCM adjusts engine idle speed through the
idle air control (IAC) motor and adjusts ignition timing
Old Mar 31, 2010 | 09:01 PM
Off_Road_Teacher's Avatar
Off_Road_Teacher
Originally Posted by RedTruck-VA
I'm thinking this should be working at partial thottle as WOT is always open loop anyway. So telling the computer the inlet temp is 20 degree cooler richens A/F at partial thottle. Anyway that's what I'm think'n.
I have the powerwire and a wideband. The a/f does not change at partial throttle with the powerwire or without. I tried both and it is still right around 14.5. Next I am going to try it WOT and see if the a/f changes any with the powerwire vs. without the powerwire.
Old Mar 31, 2010 | 09:03 PM
JoeHemi's Avatar
JoeHemi
Will be interesting to see what your gauge displays since airram says, "
The POWER WIRE has been reported to richen the AFR by one full point at WOT,
Old Mar 31, 2010 | 09:05 PM
Off_Road_Teacher
I would think that it has to have some effect at WOT, but I don't know if it going to be as much as they say. Guess we will see.
Old Mar 31, 2010 | 09:47 PM
RedTruck-VA
This is excellent evidence at what point does the PCM go close loop. Maybe only 20 degree drop is not enough to have the PCM go open loop. I don't know. If you can read the engine from a cold state perhaps it will become known. Or if an adjustable resister could be installed and monitored while adjustments are made.
Old Apr 1, 2010 | 01:16 AM
jarhead03's Avatar
jarhead03
THIS REMINDS ME OF THE ARGUMENT i HAD ABOUT THE LITTLE BLACK BOXES FOR $25 BUCKS ON EBAY THAT GIVE YOU 100PLUS HP BY ADDING IT TO YOUR TRUCK. LOL
Old Apr 1, 2010 | 01:43 AM
JoeHemi's Avatar
JoeHemi
you need to take that tonno out of your sig lol
Old Apr 1, 2010 | 07:01 AM
A05GSHO's Avatar
A05GSHO
I've got one thats been in my center console for over a year now, you can have it. I did some 1/4 mile times with it on and with it off NO real improvement, little more tire spin out of the hole . Also in the summer month's I found no real mpg increase and from what I understand it's worthless in the winter because of the cold temps.
Old Apr 1, 2010 | 07:14 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
As said before, the P/W will not give better mpg. The ONLY thing that is going to do that is keeping your foot out of it.
I mean seriously, look at my mods, Ive got an efan, ALL synth oils, gearing, ported heads, LTs, CAI, tuner and more and still no better mpg UNLESS I baby it. The bad thing is thats not fun once you have done everything I have.
The P/W is for fun at WOT only.
