do i need to go to a dealer?
Old Apr 2, 2010 | 03:34 PM
cf838's Avatar
cf838
Default do i need to go to a dealer?
I have a 2007 1500 5.7, at cold starts engine runs with a #6 misfire P0306 and has a backfire into the manifold. I replaced plugs and moved wires around to see if misfire also moved but it stayed at #6. I had the valve cover pulled off due to someone suggested a broken valve springs, but springs looked good. after about 4-5 minutes the truck runs fine. It was also suggested it maybe a bad or broken lifter.. any advise?
thank you in advance, chris
Old Apr 2, 2010 | 03:39 PM
ramhunter9's Avatar
ramhunter9
if you have a warranty why not?
Old Apr 2, 2010 | 03:42 PM
cf838's Avatar
cf838
no warranty bought it used has 45000 miles on it now..
Old Apr 2, 2010 | 03:58 PM
HammerZ71's Avatar
HammerZ71
Sounds like it's time for a compression test, dealer or preferably a decent local mechanic. That's the one thing that sucked about the "Lifetime Powertrain Warranty" it was not transferable. My '04 that I bought new would still be covered for another year from now and 23,000 miles if I sold it tomorrow for just a $100 transfer fee...
Old Apr 2, 2010 | 04:07 PM
cf838's Avatar
cf838
had a compression test done with a result of 125 psi in the #6 valve.
Old Apr 2, 2010 | 04:09 PM
cf838's Avatar
cf838
could it be a lifter?
Old Apr 2, 2010 | 04:30 PM
hoss67's Avatar
hoss67
ihave learnt one thing owning a dodge, NEver EVER take it to a dealer, i have nothing but bad experiences and lost alot of money, a local mechanic here is better and alot less expensive, but im with hammer on this one
Old Apr 2, 2010 | 04:32 PM
hoss67's Avatar
hoss67
i need to start readin the whole thread before posting i didnt see u had a compression test, my bad, but it could be a lifter, dont know for sure though
Old Apr 2, 2010 | 04:39 PM
cf838's Avatar
cf838
thanks for the replies, is there anything i might be able to check or look for? the strange thing is when it warms up the truck runs great.. i do have a tap. thats why it was suggested a possible lifter causing the rough running and manifold misfire on the cold starts.
Old Apr 2, 2010 | 05:19 PM
RedTruck-VA's Avatar
RedTruck-VA
The "tap" could easily not be related as some engines have the "hemi" tick. But back firing into the intake indicates to me that you have a lifter problem or at least a sticky valve. Are you changing the oil regularly? I don't normally recommend top end lubricate but maybe this time it would help. I would at least do a oil change to see if it helps.
