From stock 20's to 17's 02 Ram 1500 QC
Old Apr 2, 2010 | 08:40 PM
jimmygunns's Avatar
jimmygunns
Default From stock 20's to 17's 02 Ram 1500 QC
I'm getting rid of my stock 20's on my '02 Ram 1500 4x4 QC. I want to go to a 17" wheel. I'm looking at Goodyear Dura Trac in a 285/70 R17. That will put me at about 33". I'm getting a front level kit & new shocks this weekend. I'm just not sure of wheels & my offset. I've been told I can go to a 35", but I'm not wanting to go that big, hence the size I've picked out above. I'm looking at the AR ATX series wheels, but not sure if I can get away with having a -12mm offset like in the Artillery model. I'm trying not to need to put any Bushwackers on if possible. Can I do that, or do I need to stay at a 0 offset, or if I get a 0 offset, will I still have clearance on turns? This truck is going to be my icefishing truck I drive on the lakes in MN when I'm up there. I only put about 3k a year on it now, but I don't want to dump a ton of $ into it as it's not my primary ride. I've got some beer dents & scrarches on the old 20's, & it's cheaper for me to get new 17's & tires run about a hundo cheaper per tire for downsizing. Anyone happen to know what the factory wheel offset is on the 20's? Any help? Thanks!
Old Apr 2, 2010 | 09:21 PM
03MopaRamman's Avatar
03MopaRamman
You can definately run those tires on a stock 17" steel or chrome capped rim with the leveling kit and they won't rub when turning and will not stick out past fenders. They are what they call a 34 but like you say the 33.6 spec listed is probably actually 33 on the rim. They perform real good in snow and not too bad on Ice too.
Last edited by 03MopaRamman; Apr 2, 2010 at 09:23 PM. Reason: chged 34.6 spec to 33.6
Old Apr 2, 2010 | 10:08 PM
hoss67's Avatar
hoss67
Sup brother, i have stock 17's, i had a set of cooper discover stt that were 285/70/17 without the leveling kit, no rubbing at all...... i installed a leveling kit and now running 305/70/17s which is about a 34" tireX 12.1 inches wide. if u go any wider then the 285/70/17 u might rub the UCA which means u will have to get spacers like i did... since urs is older u might not have to just see how much room u have between the tire and the UCA
