Nitto mud grapplers on Stock 20"
Old Apr 5, 2010 | 01:41 AM
MexiRam's Avatar
MexiRam
Im starting to think could of went 35" on the tires but the 33" barely clear.Does anyone know if the 35" will rub?.My truck is level.Cuz if i can go bigger tires i will.
Old Apr 5, 2010 | 01:44 AM
Freakinkeith806's Avatar
Freakinkeith806
Those tires are on my list next, after these wear out in another 40K or so...
Old Apr 5, 2010 | 07:37 AM
SMKNRAM's Avatar
SMKNRAM
35's fit on a leveled truck, I have the same set up with spacer and I get rubbing on the plastic fender well. Really need a body lift to make them fit right.
Old Apr 5, 2010 | 10:40 AM
MexiRam's Avatar
MexiRam
So does it rub bad or barely? I personally think the 35's look better. But if it real bad ill stick with the 33
Old Apr 5, 2010 | 01:12 PM
SMKNRAM's Avatar
SMKNRAM
None while going straight as you can see in the pictures, but when turning especially on slopes. and it makes more noise while backing up LOL!!
I could easily fix it with a heat gun and rework the plastic, or a sawzall and trim the spot. OR just put the body lift on and forget about it!! That is what my plan is!!!
Old Apr 5, 2010 | 01:42 PM
TheFist's Avatar
TheFist
So those are 33 12.50 20's?
They look good.
Old Apr 5, 2010 | 02:59 PM
MexiRam's Avatar
MexiRam
Mine are. but smkn is running 35's.
