3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Do yuo have anything plugged into the p/s OEM light harness at all? Something like this that tricks the PCM into thinking there is a bulb on the pass side?
I still dont understand why I only have one... It looks like everything is come from the drivers side and carries all the way over to the pass side...Im going to radio shack to see if I can find one..
So what should I get, 6 ohm, or 8 ohm.... I can get high wattage right, its the ohms that is more important right... It can be fifty watts or more right.. Radio shack doesnt have them, so I am going to order one.. Like I said my lights only have one resistor..
screw those damn HIDs, I just put a new resistor in that I found in the glove box, which he must of had one extra in, and it is still flickering.... a constant flicker, like pulsating.. Im ripping the damn things out and putting the stock back in..... thanks for the help though guys....much appreciated
