Alignment after leveling kit installed....
Old Apr 5, 2010 | 09:35 AM
ThuDLux1's Avatar
ThuDLux1
Default Alignment after leveling kit installed....
has anyone had their truck aligned after the kit was installed??? or has anyone put the kit in and had no changes with the handlein of the truck???
do u think it should be done or try it first and c if it may be neccessary????
thanks..
jus puttin the 2.5 in spacers in......
Old Apr 5, 2010 | 09:39 AM
hoss67's Avatar
hoss67
Sup dude, u need to get it re-aligned. If i do believe it helps with make the truck sit better after installing the kit, I went to have mine done, but my tie rod ends are bad so gotta replace those first, but yea i recommend it, but i have known a few guys not do it for a while till they need it re-aligned, but i wouldnt take any chances
Old Apr 5, 2010 | 09:41 AM
dirtydog's Avatar
dirtydog
Moderate User
It will be necessary to have an aalignment done. Anythime you pone up the front suspension your changing the geometry even if you did nothing for change as the bolts can be a teeni bit offf from what they were.
Adding any type of lift that opens the suspension is a must for an alignment or you will wear out your tires unevenly EVEN if you are tracking straight down the road and see no reason for an alignment.
Old Apr 5, 2010 | 09:42 AM
SMKNRAM's Avatar
SMKNRAM
Definitely get the alignment!! I recommend giving it a few days to settle but then for sure!!
Old Apr 5, 2010 | 10:33 AM
TRXHemi's Avatar
TRXHemi
The tires will wear funny if you don't.
Old Apr 5, 2010 | 10:39 AM
RubberFrog's Avatar
RubberFrog
Don't worry about an alignment. Just get new tires every couple of months.
Old Apr 5, 2010 | 10:57 AM
dirtydog's Avatar
dirtydog
Moderate User
Now that won't be very cost effective
But i guess people can trick themselves into believing whatever they want.
Old Apr 5, 2010 | 11:06 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I have had my alignment SO FAR off i have had to adjust my tie rods just to get it to drive so I could GET to the shop.
Old Apr 5, 2010 | 11:40 AM
BEAR's Avatar
BEAR
realignment is a must not a maybe, or you can do like Frog said and buy tires every couple months,lol.
Old Apr 5, 2010 | 12:16 PM
ramhunter9's Avatar
ramhunter9
on my truck after the suspension lift ect i went to get a alignment and they didnt charge me because it was not off . prob different on my SFA than a IFS .
