03 Hemi 5.7 replacement?
Old Apr 5, 2010 | 03:41 PM
BobConley's Avatar
BobConley
Post 03 Hemi 5.7 replacement?
Hi guys
I have been looking to find some info about replacing an engine and all I can find is people doing different swaps. errrr
I have an '03 Dodge Ram 4x4 Quad Cab with 5.7 hemii and I want to replace the engine. The current engine had horrible maintenance and it took a dump on me. Going down the highway I started to smell oil burning, then all of a sudden the oil dropped to 0. Then it came back after shutting off the engine but I have nasty valve train noises...
Anyway, I want to replace that engine with another Hemi 5.7 but I was wondering what years I can swap with and not have to change anything else or change things the least. I see that Gen 3 is 2002-2008 so can I swap with a Hemi from an '06 without changing wiring harness, etc?
Also I found an engine on Craigslist that has 47,000 miles and runs good but has a wrist pin problem, so what would I have to do to take care of that before I swap the engine. And also, does anyone have any tips or thoughts on what else I should look at or do to the new engine before putting it in?
Thanks, I have not been able to find much info on this and have been reading the forum for a while before signing up!!!
Old Apr 5, 2010 | 03:57 PM
AF_HEMI's Avatar
AF_HEMI
the 03 PCM is unique. The 04-05 PCMs are the same, and 06-08 are the same. The motor itself is different from 06-08 because of the MDS. If you're looking for a straight swap, its gonna have to come from an 03, otherwise you'll be swapping the PCM and wiring harnesses out also
Old Apr 5, 2010 | 04:37 PM
BobConley's Avatar
BobConley
So would it probably be eaiser to rip it down and rebuild it. Any idea on costs and a good place for parts?
Thanks for the quick reply!
Old Apr 5, 2010 | 06:31 PM
AF_HEMI's Avatar
AF_HEMI
inertiamotorsports.com for parts. not really much idea on cost. $2k for stock, probably $3k for a performance build? those are wild shots in the dark
Old Apr 5, 2010 | 06:44 PM
RedTruck-VA's Avatar
RedTruck-VA
Might try an auto parts store like Auto Zone for a remanufactures engine. I would just rebuild the original engine.
