Just Did the LED Dash
Old Apr 7, 2010 | 09:43 PM
AWE Daniel's Avatar
AWE Daniel
Default Just Did the LED Dash
I got my leds in the mail from superbrightleds.com today and popped em in. I ordered white but they either sent me blue or the dash has some sorta film but either way I like em. I dont have any of that paper stuff to change the PDRN so all thats still green.
sorry from the crappy cell phone pic
Old Apr 7, 2010 | 09:44 PM
SilverBullet08's Avatar
SilverBullet08
yea the dash has film over it...
Old Apr 7, 2010 | 09:47 PM
ramhunter9's Avatar
ramhunter9
how hard was this mod got any details
Old Apr 7, 2010 | 10:50 PM
huseman808's Avatar
huseman808
can you tell us what types(as in the number) of bulbs you ordered? this is somehting im looking at doin as well.
Old Apr 7, 2010 | 11:03 PM
Matt99's Avatar
Matt99
There are 10 DIY on this ( I think frog did one). There is a blue film that makes the yellow halogen bulbs look green, so blue is pretty much one of the only colors you can do
Although, I was wondering if you did red if it would look purple? I dont want to do blue, so maybe I need to do some experimenting.
8 B8.5D Cluster and HVAC
3 NEO4 (overhead console homelink and computer buttons)
2 WLED-X the single led type (4x4 switch and headlight switch)
1 #74 (rear sliding window switch)
3 4210-CWHP6 (dome light and map lights)
Old Apr 8, 2010 | 07:23 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Looks good. Where are the "work in progress" pics and hpw hard was it for you? Any thing tricky or something you didnt like?
Old Apr 8, 2010 | 02:13 PM
AWE Daniel's Avatar
AWE Daniel
Yeah sorry I meant to take pictures but the camera was missing somewhere. All you need to do is pop off the radio bezel, and the headlight switch trim, Then there are 2 screws holding in the trim around the cluster at the top, then that pops off. Then there are 4 screws holding the cluster itself in. Then you have to pop off the three wiring harness, the two on the left were easy, the one on the right was a pain to get off, Needle nose pliers helped there.
Like Matt99 said you need the B8.5x leds from superbrightleds.com (11 for the 02-05) (I think 6 for 06 and up) .I was tempted to get the high output ones, but I was worried they would hotspot too much. When you look at the back of the cluster you can see all but one of the old lights, they look like the new one except the plastic on em is black. The one you cant see is under the chime module right in the center, so you gotta pop that thing out. Just twist the old bulbs out with some needlenose pliers and twist the new ones back in. The new ones are polarized so I had to go plug the cluster back in and see which ones weren't lighting up, then twist them 180 deg so the pins switched places. Once there all light up yur done! Took about 30-45 min, pretty easy. If you want to change the PDRN you need the special film, and you gotta take apart the digital display part and replace the film, Im kinda scared to rip that apart so I might not do it.
Old Apr 8, 2010 | 02:42 PM
BadHab1t's Avatar
BadHab1t
hmmmm sounds easy enough and looks good wish i could do red....
Old Apr 8, 2010 | 03:11 PM
AWE Daniel's Avatar
AWE Daniel
I think you can rip that film out and replace it with wax paper, just order the high output red leds I'm pretty sure that will work. IF not im sure they sell that paper in red.
In fact here is the first thing i found http://www.adorama.com/Als/ProductPage/RO120.html
Old Apr 8, 2010 | 03:23 PM
BadHab1t's Avatar
BadHab1t
hell yeah thanks
