Wiring Delema
Old Apr 8, 2010 | 08:14 PM
BadHab1t's Avatar
BadHab1t
unless you got a huge washer small hole than thats gotta go thats barley grounding no surface coverage....either grind that more so the whole eye is touching and put a washer on it or get new eyes the proper size...
Old Apr 8, 2010 | 09:10 PM
OlDirtyJohn's Avatar
OlDirtyJohn
ill second what jay said. use the correct size eye. the one you are using is for a huge bolt and 10-12awg wire. or you can try to run it without a relay. thats what i did when i ran the 12awg wire and 100w bulbs. works great.
Old Apr 8, 2010 | 09:17 PM
BadHab1t's Avatar
BadHab1t
man i been on yahoo im with him for a while telling him this stuff he kinda fixed it with a washer and now hes going to buy a new fuse holder ...i say he needs to get out the d.multimeter and find where the voltage is and why its getting hot and do some troubleshooting....
Old Apr 8, 2010 | 10:16 PM
Shiloh 24's Avatar
Shiloh 24
replaced that freakin glass tube fuse holder with a blade fuse holder and it works great, no heat issues at all. I don't know what was up.
Old Apr 8, 2010 | 10:46 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You guys are on the right track. Bigger power and ground wires. Better ground connections with PROPER terminals and checking all the connections. He is lucky he doesnt burn his truck to the ground
Old Apr 9, 2010 | 12:51 AM
Shiloh 24's Avatar
Shiloh 24
No faith? I was just tryin to make a quick fix today and figure out the big problem, I never even turn em on anyway lol. If you say I need to upgrade wiring I'll upgrade the wiring, and I know the grounds are redneck as hell but I couldn't find any smaller ring terminals in this freakin tiny town.
Old Apr 9, 2010 | 01:04 AM
JoeHemi's Avatar
JoeHemi
So what size wire and relay are you running right now? What size fuse did you replace the old one with? If you have a walmart nearby, you can get everything you need there. Or a lowes, home depot, or any other hardware/stereo/auto store out there.
Old Apr 9, 2010 | 01:25 AM
Shiloh 24's Avatar
Shiloh 24
thats all walmart and the local autoparts had
Old Apr 9, 2010 | 02:50 AM
AWE Daniel's Avatar
AWE Daniel
Another thing is those grounds are too far away, i grounded mine right on the crossmember less than 6" away.
Old Apr 9, 2010 | 07:10 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I think once you upgrade the wiring and fuse you will be ok.
