not an ordinary e-fan ?
Old Apr 13, 2010 | 08:53 PM
  #21
badblackram06's Avatar
badblackram06
What year model taurus have the 24" fans? I may be able to get a few. No body around here would even think about an efan mod. I called a few junk yards on my lunch break today and they have a few 96 models and a several 2000 models.
Old Apr 13, 2010 | 08:59 PM
  #22
BadHab1t's Avatar
BadHab1t
itd be a 3.8l ford taurus efan i think them models were 93,5,6,7 im not positive tho....
Old Apr 13, 2010 | 10:19 PM
  #23
SMKNRAM's Avatar
SMKNRAM
Jay, the junk yard I got mine at had 3 when I got mine in feb, called today they had none, I will keep an eye out for you guys that are looking for them
Old Apr 13, 2010 | 10:29 PM
  #24
stenerson's Avatar
stenerson
I've heard that the electric fan from a 2000 grand cherokee 4.0 fit's perfectly in the Hemi shroud.
Old Apr 13, 2010 | 11:04 PM
  #25
dirtydog's Avatar
dirtydog
Moderate User
I think it's an earlier time frame, from 90-95 3.8L's 96 might be included but i don't know that for sure. The Motorcraft fan that i purchased was for 94-95 Taurus 3.8L's . the 96+ were newer rounder body style so they change some stuff. But they could work
Old Apr 13, 2010 | 11:10 PM
  #26
Matt99's Avatar
Matt99
they have a ton of them here, cost $15 at one place and $7 at another. If they weren't so fragile I think itd be worth puling one and sending it
Old Apr 13, 2010 | 11:49 PM
  #27
badblackram06
I may call around at other places and see if they have a early 90's model, i doubt it though. I never get that lucky.
Old Apr 14, 2010 | 03:07 AM
  #28
flwalks's Avatar
flwalks
oe the intrepid fan is only 27x14 rectangle with 2 fans....our trucks rad is 24x20 and smaller to fit the stock shroud....ill keep hunting....does anyone know if any of the ford ranger fans are the same as a taurus fan?
I have a dual fan from a ford, I think, in my garage that is 24" X 14. I think the dual fan would work great if you staged them. Most of the time only one fan would run and you could get by with the smaller relays.
Old Apr 14, 2010 | 07:36 AM
  #29
BadHab1t's Avatar
BadHab1t
How much you want Tampa a rock thow away and do you know what it was out of and if it blows enuf air to keep our engines cool in the fl heat?
Old Apr 15, 2010 | 02:41 AM
  #30
flwalks's Avatar
flwalks
Just a little north in SpringHill. Not sure if it will fit under the shroud. Bought it thinking I would remove the shroud and replace the coolant overflow and washer tank with custom stainless replacements. They move a lot of air when both are running and covers a big part of the radiator.
