20" wheel and tire combo
Old Apr 13, 2010 | 08:12 PM
chiefdano's Avatar
chiefdano
Default 20" wheel and tire combo
I have an 04 SLT Quad 2wd, stock.
looking at this wheel
http://www.discounttire.com/dtcs/whe...AAINT&pc=22344
and this tire
http://www.tirerack.com/tires/tires....&autoModel=Ram 1500 QuadCab 2wd&autoModClar=
will I have any rubbing problems or fitting problems?
Thanks
Dan
Old Apr 13, 2010 | 08:27 PM
explorer9950's Avatar
explorer9950
you should have no issues...the tire is slightly skinnier than what your stock tires should of been, if you had 20's already...I would say no issues should be had with that setup
Old Apr 13, 2010 | 08:39 PM
chiefdano's Avatar
chiefdano
cool thanks.
Any idea how they will fill the well out?
Old Apr 13, 2010 | 10:05 PM
explorer9950
Well, the tire is a 31.9 inch tall tire...if your leveled in the front, it may be slightly small, if your not and still have the rake, it will look ok in the front, and a bit small in the back...should have no rubbing issues tho...I just put some 35/12.5/18 on my 07 2wd with a level kit...only had minor rubbing...so a 31.9 inch tire should be no issues...
Old Apr 13, 2010 | 11:31 PM
chiefdano's Avatar
chiefdano
Nothing has been modified on this truck
I was afraid they'd be a little big, but it seems a little small. What would the tallest tire to fit that wheel?
Old Apr 17, 2010 | 04:22 AM
hornytruck58's Avatar
hornytruck58
i put 35/12.50/17 on my 07 1500 without a leveling kit and it works fine because i dont have the rear wheel wel,thats where they normaly should rub
Old Apr 17, 2010 | 08:25 AM
explorer9950
biggest tire i would go with would be a 33" tall tire...which would be a 275/60/20 size...
Old Apr 17, 2010 | 11:10 AM
crazyandy202's Avatar
crazyandy202
Those will look pretty sweet Liking the rims
