Trouble Code PO480
Hello!
I'm from Germany and got a 2003 RAM 1500 with trouble code PO480. I really tried everything: I changed the relay, it's not the fuse and the fan is running if connected to a 12V batttery. If I mesure the continuity at the wire going to the fan I only have 5,5 volts. I also checked the electrical center, no broken curcuit path... No German Dodge owner can help me. I'm very for every idea you guys might have. Sorry for bad english. Nice hello from Germany:
André Struss
André Struss
on
If I'm not mistaken there was a Dodge TSB on the '03s and early '04s about a wiring problem for the blower as it came from the ignition switch. I believe a dealer can run your VIN and and tell you if the technical service bulletin includes your vehicle. The TSB provides the instructions for a wiring overlay.
