subs and lights
Old Apr 15, 2010 | 01:12 AM
jms2291's Avatar
jms2291
Default subs and lights
so i tryed searching the diy section and i guess i was doing something wrong cause it kept telling me no results found
---anyone got any plans or a link to help me with some ideas to build my box under the rear seats?
---anyone know if the 2007+ tailights will fit in an 05?, i really like the look and though about upgrading
thanks
Old Apr 15, 2010 | 02:03 AM
Shiloh 24's Avatar
Shiloh 24
thanks
The box would be easier to just buy, most guys run the fox box and it's pretty well reviewed and recommended.
As for the tail lights, they will fit just fine but there is a wiring difference that has to be corrected for them to work right. Hope this info helped.
Old Apr 15, 2010 | 11:41 PM
Jonhyboi's Avatar
Jonhyboi
there are some people that made some custom ones. if you want to give it shot you can. kx250frider617 has a post of how he did his step by step if you can find it.
Old Apr 16, 2010 | 12:09 AM
jms2291's Avatar
jms2291
what exactly is the wiring issue with the lights?
i mean is it something major/pain in the a$$ or just a minor fix?
Old Apr 16, 2010 | 12:14 AM
Shiloh 24's Avatar
Shiloh 24
Last I knew you just had to swap a couple wires around and boom your done, but I could be wrong.
Old Apr 16, 2010 | 12:21 AM
jms2291's Avatar
jms2291
ok, thanks maybe someone will chime in who has done this...
Old Apr 16, 2010 | 12:33 AM
mmstar23's Avatar
mmstar23
Sub Box: I would lay fiberglass and simply mount a top piece of MDF, cut your holes and youre done. port it if your subs recomend it. someone else may chime with better details, but i would deffinatly lay fiberglass in the buckets.
Tail Lights: The actual light fits, only difference is the wiring harness. the 03-06s use 1 harness that plugs into a board, the 07-09s use 2 harnesses that plug into a bulb, which then twists into the housing. simply cut off the old harness, go to the dealer and buy the new harnesses, and splice in your wires accordingly. to find what wire does what, use a volt meter.
