Shift Lever Problems--Need Pointers/Help
Old Apr 16, 2010 | 07:54 AM
NoFearEyes's Avatar
NoFearEyes
Default Shift Lever Problems--Need Pointers/Help
Have a 2002 RAM 1500 QC 4X4 with 5.9 and Sport trim package.
Dealer performed a recall for some obscure shifter problem--now I just found out I have two new problems--and they make no sense. Would appreciate a pointer as to where to start looking--
1> Difficult to get shifter into PARK--sometimes have to try 3-4 times before park activiates and indicatopr actually shows it's in PARK..
2> When I shift in 1 the entire electrical system shuts down like I turned off key !!!
Where should I start looking--the dealer is 30 miles away and it's bee 2 months so they are going to say NFW--
Would appreciate thoughts/suspicions...
Old Apr 16, 2010 | 08:16 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I would take the top half of the steering column cover off and try to change gears and watch the mechanism for binding or anything like that
Old Apr 17, 2010 | 01:54 AM
NoFearEyes's Avatar
NoFearEyes
How difficult is it to get the plastic off steering column? I can't feel any screws but then I haven't tried to get contorted enough to see underneath column--
Is there a wiring diagram of that area to see what night be cuasing it to go dead when I shift into 1 >>
Old Apr 17, 2010 | 03:19 PM
05RamMan's Avatar
05RamMan
problem number 1 sounds like possibly Transmission range sensor, Although this would normally throw a code. For problem number 2, I cant see anything in the diagrams that would cause this, Unless maybe there is a break in the ignition power wire and when you shift to 1 some how you are tweaking just right.
Old Apr 18, 2010 | 05:43 PM
NoFearEyes's Avatar
NoFearEyes
THanks for replies--
Tried going into 1 slowly and it didn't shut down electrical system so I guess something is tweaking the wire-
Thanks again
