Take a look at this list and tell me if I am missing any parts
3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Ok Thanks Frog. I only have one Cam swap under my belt and at the time I left the cooler attached to the rad when I pulled it out and found it difficult to get the KD Brand overhead Valve compresser tool in on those ones around the booster. I do believe in Wildecoyote and alternative methods kinda like Reverse Engineering can be accomplished using a pipe wrench. I also didn't have you Guys for support at the time.
on a seriuos note I've seen a cam insall recently where they used royal purple break in lube or just the grease (by rp btw) Too coat all the parts when installed. Good luck teach need a camara for pictures!!
