overhead on board reads -40*??
Old Apr 17, 2010 | 08:08 AM
Dieselmonkey's Avatar
Dieselmonkey
Default overhead on board reads -40*??
Good morn'in all, wondering if anyone has experienced this before, on occasion when I start my truck the overhead computer will read -40 degrees. If I shut the truck off and start it back up it will clear it. But the other morning on my way to work about a mile down the road the c.e.l came on started to blink then the truck just died out and check gauges light came on but left no codes WTF?? It started right up after this. I did'nt notice what the overhead was reading at the time (5:45am) Iam running SC performance tune. any input would be appreciated, thanks
Old Apr 17, 2010 | 08:55 AM
dirtydog's Avatar
dirtydog
Moderate User
What's the year of your truck and what engine do you have so guys can better assist you.
Old Apr 17, 2010 | 08:59 AM
Dieselmonkey
its a 2006 5.7hemi, thanks dirtydog
Old Apr 17, 2010 | 02:07 PM
Tazman40's Avatar
Tazman40
my 06 hemi has started doing the same thing.It will read -40 for a few miles then will slowly start to climb and read normal.Will be ok for a week or so then do it all over again.Im not running any tuners or anything.Shes all stock.Everything seems normal just the reading is whacked
Old Apr 17, 2010 | 03:02 PM
rbeard79's Avatar
rbeard79
Mine does this as well, but only when I remote start my truck with my Viper 5901 RS. The RS is hooked into the data (canbus) wire so it can start the truck, and I have been told that is what is causing it to read like that. I know you didn't mention a RS, but it might be something messing up in your canbus system???
Old Apr 17, 2010 | 03:51 PM
Dieselmonkey
Hey thanks for the input guys. I guess its just a minor glitch in the system just hoping it doesnt lead to more serious issues down the pike. I will check that data wire like rbeard79 suggested.
Old Apr 17, 2010 | 04:09 PM
Snoman's Avatar
Snoman
There is a service bulletin out on this issue with certain trucks.
Take it to the dealer for a software update if the temperature reading returns to normal after a time, if it stays at -40 there is a possible open circuit in the system and a software update wont fix it. Hope this helps.
Old Apr 17, 2010 | 05:12 PM
OklaHemi's Avatar
OklaHemi
are you in wyoming? i found this temp to be common there. brrrrrrrrr. i hope you get it worked out or move a little further south
Old Apr 17, 2010 | 05:46 PM
JoeHemi's Avatar
JoeHemi
If you do happen to take it to the dealer, make sure you return the truck to stock first (remove the superchips tune) before they flash the truck.
Old Apr 18, 2010 | 10:10 PM
Snoman's Avatar
Snoman
