need opinions! engine swap or build current engine
Old Apr 18, 2010 | 03:52 PM
kkuzmicki14's Avatar
kkuzmicki14
Default need opinions! engine swap or build current engine
hi guys so I currently have a dodge ram hemi 2wd. I have a t56 magnum swapped in there that can handl3 700-800hp. I would like to eventually achieve that kind of power but I'm not sure which route to take. There is the first route to rebuild my engine with new connecting rods, pistons, crank etc. And than throw on a supercharger or twin turbo running at roughly 16psi getting me to around the 700hp range. The cost of this would definitely run in the 8 grand+ range. This being said what if I just put a new engine there. A big block of some sort that can make 600 naturally aspired horsepower. There are plenty of bellhousings that can easily mate the engine to my transmission so that wouldn't be an issue. The only issue i see is making my electronic work. Anyway I welcome all opinions! thanks
Old Apr 18, 2010 | 04:09 PM
RedTruck-VA's Avatar
RedTruck-VA
Pick your poison:
http://www.inertiamotorsports.com/MOTORS.html
Old Apr 18, 2010 | 04:21 PM
kkuzmicki14
Originally Posted by RedTruck-VA
based of that I'm guessing you like the build your motor rather than new motor option?
Old Apr 18, 2010 | 04:26 PM
oefootball_70's Avatar
oefootball_70
new motor
Inertia Premium 6.1L Based 426 HEMI Stroker Package
$9665*
6.1 HEMI Block
Custom Ground Performance Camshaft
Callies Compstar Rotating Assembly
Crower or Manley Pro I Beam Rods
Custom CP Pistons
Gas Nitrided Steel Top Rings (1.2/1.2/3.0 ring width)
360 Degree Oiling
Main Cap/Saddle Radiusing
6.1L Premium Big Valve Cylinder Heads
PAC/Manley Valve Spring Upgrade
16 Custom Forged Pushrods
Ported 6.1L Aluminum Intake Manifold
CNC Ported Throttle Body
Edge Performance Torque Converter
* Core charges apply if not installed by one of our Authorized Installers. Please contact us for details.
Old Apr 18, 2010 | 05:47 PM
kkuzmicki14
Originally Posted by oefootball_70
new motor
$9665*
6.1 HEMI Block
Custom CP Pistons
360 Degree Oiling
that all sounds really nice but like it says roughly ten grand with I would guess roughly 500-550hp? (I may be wrong...feel free to correct me). For that kind of money I feel like I could be pushing closer to 700hp. Also with that package would they accept my 5.7 engine as a core? Is that what they are asking for?
Old Apr 18, 2010 | 07:36 PM
oefootball_70
what about this
392 or 407 HEMI Stroker Shortblock
$4995*
6.1 HEMI Block
Custom CP Pistons
360 Degree Oiling
and this
http://axztm.huwab.servertrust.com/P...de=turbotuner1
That should put down some great numbers. I would think. Along with all the supporting mods. The best part is the turbo kit comes with the tuning needed to tame the motor then move to the turbo set up.
Pushing this much HP I would look at then going to
http://moesperformance.com/index.php...oducts_id=3254
That should do you nicely.
EDIT oh nvm, already have a good tranny.
I guess you could always build up the motor you got.
I would try to do a 392 if you are trying to save money for the turbo. There is a couple guys running 392 single turbo and putting good numbers, not 700 hp. I believe 562 (off the top of my head). So with the 407 twin turbo you could prob get to where you wanted with a nice shot of NOS on top of it all.
Old Apr 18, 2010 | 08:13 PM
RedTruck-VA
I wouldn't be stuck on the 700hp so much as a 550hp streetable engine. Don't want to paint yourself into a corner. A big motor that can be driven is a lot more fun than a really big motor that can't be driven.
Old Apr 18, 2010 | 08:23 PM
kkuzmicki14
what about this
$4995*
6.1 HEMI Block
Custom CP Pistons
360 Degree Oiling
and this
now thats starting to look better, Do you any of the numbers these engines output? without the turbo or supercharger that is?
Old Apr 18, 2010 | 08:24 PM
kkuzmicki14
sorry mis type do you know any of the numbers these engines output?
Old Apr 18, 2010 | 11:51 PM
05RamMan's Avatar
05RamMan
No reason one couldnt squeeze these numbers out of a truck.
http://www.youtube.com/watch?v=n7cc_...layer_embedded
