Wheels and Tire help???
Old Apr 20, 2010 | 08:38 AM
mikbimdre's Avatar
mikbimdre
Default Wheels and Tire help???
I need some help. I just bought the PA 3" body lift kit and the AAC Halos. I haven't put them on yet but when I do it is going to look really dumb with the stock 17" tires I have on now. I've searched around here and I can't really find a good thread that gives me a bunch of options for what will fit on my truck. Does anyone have suggestions. I want a bigger tire but I don't really know how big I can go or how wide? I'm kind of new at all this stuff. And I'm not against getting some new wires either.
Old Apr 20, 2010 | 09:50 AM
HammerZ71's Avatar
HammerZ71
First of all, unless you are a big fan of the "rake" look, I'd either crank the front key bolts a bit or look into a set of inexpensive leveling keys to go in combination with the body lift. This will also give you the added lift in the front you are gonna want if you opt for 35" tires.
At that point, any good A/T or M/T tire in the 33" to 35" range would be a good choice. If you want to go 12 -12.5" wide on the tires, then replacing the wheels with a 17x9 wheel with a 0 to negative offset and about 4.25 - 4.5" of backspacing would be highly advisable.
Personally, I've always been a big fan of the Mickey Thompson and Dick Cepek wheels. They offer a good looking wheel at a very competitive price and their strength to weight ratio is about the best you'll find out there.
As far as tires go in 17", it's a big part personal preference and what you plan to do with them. For mostly on pavement with some weekend jaunts off-road, most popular choices are the Nitto Terra Grappler, Toyo Open Country A/T or Mickey Thompson ATZ. The Terra's are not overly expensive, offer about the best wet and dry pavement ratings and are surprisingly quiet for a fairly aggressive A/T.
My Cepek FCIIs are a fantastic tire for a combination on road with a bit more aggressive off-road characteristics and along with the Super Swamper M16s and Nitto Trail Grapplers are filling the niche between an A/T and M/T tire quite nicely. The Cepeks are at the upper end of the $ range, but at 29k mine still have well over 90% tread on them, by far the longest lasting tire I've owned in over 25 years of having 4x4 trucks and SUVs. The only downside is that they are about as loud as all but the most aggressive true M/Ts...
Old Apr 20, 2010 | 12:22 PM
mikbimdre's Avatar
mikbimdre
This may be a stupid question but I think the previous owner put a leveling kit on it because the front seems to be leveled with the back, what can I do to check to see if he installed one or not.
Old Apr 20, 2010 | 12:41 PM
cwboyjohnny24's Avatar
cwboyjohnny24
park the truck on level ground and measure the front and rear tire wells. Just from the pic it doesn't look too level, but that may be the uneveness of where you were parked.
Old Apr 20, 2010 | 02:00 PM
mikbimdre's Avatar
mikbimdre
Here is another picture. It looks to me like the gaps are pretty even. I'll measure it tonight but either way do you think it is worth adding the level if it looks this close. I'm definitly not against adding the keys, i'm really just wondering if i have them already or not.
Old Apr 20, 2010 | 02:49 PM
cwboyjohnny24
IMHO it looks if anything the previous owner cranked the t-bars. Looks like you may still be able to up just a bit and it be perfect. Hey, it's a free lift if you measure it and it's not quite level.
Old Apr 20, 2010 | 03:19 PM
SMKNRAM's Avatar
SMKNRAM
yes I agree crank a couple more turns, get the BL and some 35X12.50's
Old Apr 20, 2010 | 03:29 PM
hoss67's Avatar
hoss67
Here i got the same wheels as you, and this is my setup
Old Apr 20, 2010 | 05:02 PM
mikbimdre's Avatar
mikbimdre
Do you guys agree that I should get rid of the stock rims and go with the wider ones. Or just put some bigger tires on? It looks like hoss67 still has the stock 17". Did you just add wheel adapters to push them out a bit to give you more clearance. By the way I do appreciate all the advice.
Old Apr 20, 2010 | 05:44 PM
hoss67's Avatar
hoss67
yea just got 1.5" hub centric adapters... rides just fine, and gives it a great stance.... look up at SMKNRAM i think he also has spacers too, and gives him a great stance too
