home made cai question?
Old Apr 21, 2010 | 09:10 AM
  #21
weedahoe's Avatar
weedahoe
Hall of Fame Member
Wouldnt there be a vacuum in the box from the engine sucking air?
You dont need a huge amount of vacuum. You just need enough to pull out saturated air.
Old Apr 21, 2010 | 09:32 AM
  #22
matthewbeard's Avatar
matthewbeard
yes there would be a small vacuum in the air box. if you hooked it up to one of the capped ports on the intake the vacuum effect would be larger due to the buttery fly on the TB being closed or part
Old Apr 21, 2010 | 09:42 AM
  #23
00dakSport's Avatar
00dakSport
i didn't relize it needed vacum for ventalation.
i thought when it needed to stuff would just vent out.
if i don't see any gunk on the filter after awhile i guess i need to put a bung in the intake. my enigine has the same oil fill tube, except i have a pcv where ur breather hose is. and my breath hose is where ur pcv valve is i guess. lol
i'm not getting rid of the pcv valve i agree that would be a bad idea.
Old Apr 21, 2010 | 09:55 AM
  #24
Mega-Hemi's Avatar
Mega-Hemi
I would be afraid of having too much vacuum if connected directly to the intake. Too much vacuum in the crank case could actually suck dirt and water through the crank seals couldn't it?
Old Apr 21, 2010 | 06:46 PM
  #25
hoss67's Avatar
hoss67
i just took a piece of medal cyclinder thingy laying around the garage that the hose would fit, cut it, and glued and siliconed it in.. its right beside the shield
Old Apr 21, 2010 | 06:56 PM
  #26
rocket23's Avatar
rocket23
^^^^Not good and feeding your tb and inards with unfiltered,oily,engine breath! Not my idea of a breath of fresh air. Trust me that set up will KILL your motor from the inside out!
Old Apr 21, 2010 | 07:05 PM
  #27
Mega-Hemi's Avatar
Mega-Hemi
^^^ That set-up is what 90% of the stock set-ups are like, they all plug in between the filter and the TB.
Old Apr 21, 2010 | 07:23 PM
  #28
Denniss66's Avatar
Denniss66
yeah mine is definatly plugged into the air box after the filter and before the throttle body. my hose came off and dirt was getting sucked in there and when i started my truck one day just boom blew my intake into pieces.
Old Apr 21, 2010 | 07:27 PM
  #29
Pyro's Avatar
Pyro
I Beat Tetris
I stuck a mini air filter on mine, $9 at autozone and the truck runs fine.
Old Apr 21, 2010 | 08:27 PM
  #30
hoss67's Avatar
hoss67
thats how it was on the stock filters
