Differential Fluid Change.
I want to change my Diff fluid on my 4x4 08 Ram this weekend, but i am reading a lot of conflicting info on here and would appreciate some clarification.
1. Some say 75W-90 for front and 75W-140, some say 75-140 for both.
2. Some mention the necessity of the Friction Modifier Additive for the rear while some say Synthetic gear oil already has it.
3. How do i know if i have the LSD differential ?
Thanks,
Pete
Thanks,
Pete
If stock / you do ! imo. your manual says 90 weight in the front and 140 in the rears. Yes it is necessary for the lsd to work properly and yes ,most synthetics already have it in. for the application I went with vlvoline, A good synthetic and has the modifiers added per the web site btw, most labels say it is included in their respective products. Double check with the mfg. and get a dealer build sheet on your truck it's free that will say everything that is put in the truck. good luck and welcome too df.
Sounds a little low in both area's Did you put your finger in the refill hole to the first knuckle and feel oil when refilling? And did you pump the oil out or crack the pumkins? what did you find? And lastly where are the pics??
ps. glad I could help (at least one person here) CC. too A.m. and Rh.
