anyone ever use this ??
Old Apr 21, 2010 | 03:44 PM
ramhunter9's Avatar
ramhunter9
Default anyone ever use this ??
doing a diff service and this stuff had a good price ....anyone ever used it . also i know i need 3 quarts rear , anyone know how much for the front ?? 2500 axles hear not 1500
http://www.oreillyauto.com/site/c/de...keyword=75w-90
Old Apr 21, 2010 | 03:51 PM
rocket23's Avatar
rocket23
Thats my stuff dude I have no complaints it is the real deal and the additive is already in per the web site /not the bottle btw. I liked the price as well special;ly for a full synthetic name brand like valvoline.
Old Apr 21, 2010 | 05:28 PM
ramhunter9's Avatar
ramhunter9
well i dont need the additives so im told . only 1500 use additives , so will it hurt to put it in anyway ??? dogg where you at ???
Old Apr 21, 2010 | 05:34 PM
Gone Fishin's Avatar
Gone Fishin
Ram------relax, you don't need the additive
The 10-1/2 diffs with Limited slip for the 2500 are different than the "light corporate" 9-1/2's. The front diff is open---not LS.
I put Mobil1 in mine when I did it, no additives, no problems----thousands of miles ago.
Hope this puts your mind at ease!
Old Apr 21, 2010 | 05:37 PM
HammerZ71's Avatar
HammerZ71
I would imagine that's the stuff you'd get if you went and had the dealer do it. I know that the Valvoline has (or at least had) the Mopar contract for their full synthetic crankcase oil.
Would be my bet that Valvoline makes all their synthetic lubes.
And you'd be fine with it, you'd be hard pressed to find a full synthetic that does not have a friction modifier already in it.
I found with my Jeep, that I still had to add about half the recommended amount of friction modifier to keep my lockers 100% quiet even though the Royal Purple said it was already in there. So I question how much of it is in there anyway...
Old Apr 21, 2010 | 05:49 PM
ramhunter9's Avatar
ramhunter9
hey gone ??? how much fluid does your front hold ??
and did you do 75w-90 in front and back ?? or just the front and used 75w-140 in the rear ????
i know i will probably use the valvolin in her , and i know 3 quarts for the rear just dont know about the front . I also know i have a re-usable seal .
Old Apr 21, 2010 | 06:02 PM
dirtydog's Avatar
dirtydog
Moderate User
That's good stuff, but you'll wanna put in 75w-140 both front and back. The rear diff calls for 80w-90 for light duty and 75w-140 for heavy duty and towing. That's your category.
However, I hate to say it but you'll need more than 3qts.
The rear diff calls for 7.0pints which comes out to 3.5qts
The front diff calls for 8.5pints which is 4.25qts.
If you get 75w-140 to do both, you will need 8qts total.
I'd use Mobil 1 or Valvoline...whatever is on sale if at all.
If you get any chatter at all, you'l wanna add firction modifier, but it should have enough in already. I don't underastand why the manufacturer doesn't reccomend it for the newer 2500/3500 series trucks as they are identical to the old one's. Clutch packs need modifier. ALL of them.
Old Apr 21, 2010 | 06:15 PM
ramhunter9's Avatar
ramhunter9
shees 8 quarts wow didnt think from lookin but the front dif looks way smaller but it holds more???
i did a search .....in ODJ's DIY he used 3 quarts in the rear of 75w-90 ?? and he has a 2500 ?? shouldnt i do the same hear ??
see im getting all mixed reviews hear ?? i was also reading from another member 2500's need no modifier ???
Old Apr 21, 2010 | 06:40 PM
Gone Fishin
Dry fill capacity. Depending on type and size of internal cooler, length and inside diameter of cooler lines, or
use of an auxiliary cooler, these figures may vary. (Refer to 21 - TRANSMISSION/AUTOMATIC/FLUID -
STANDARD PROCEDURE)
MANUAL TRANSMISSION
G56 5.67 L (12 pts.)
GETRAG 238 2.2 L (4.2 pts.)
NV5600 4.50 L (9.5 pts.)
NV4500 3.79 L (8.0 pts.)
TREMEC T-56 2.27 L (4.8 pts.)
TRANSFER CASE
NV241 GENII 1.6 L (3.4 pts.)
NV243 1.6 L (3.4 pts.)
NV244 GENII 1.6 L (3.4 pts.)
NV271 1.89 L (4.0 pts.)
NV273 1.89 L (4.0 pts.)
FRONT AXLE ± .03 L (1 oz)
C205F 1.6 L (56 oz.)
9 1/4 AA 2.2 L (76 oz.)
9 1/4 AA EL 2.2 L (76 oz.)
REAR AXLE ± .03 L (1 oz)
9 1/4 2.1 L (72 oz.)***
10 1/2 AA 2.5 L (85 oz.)
10 1/2 AA EL 2.5 L (85 oz.)
11 1/2 AA 3.6 L (122 oz.)
248RBI (DANA 60) 2.8 L (46 oz.)****
fill to 3/4" below fill hole and you're good to go-------the above it from the FSM
8oz to a cup, 32 oz to a quart
TRANSFER CASE
Recommended lubricant for the NV241 GENII, NV271, NV243, NV244 GENII, and NV273 transfer cases is Mopar
T
ATF +4, Automatic Transmission Fluid.
AXLE
NOTE: DaimlerChrysler recommends using Mopar
T lubricants or lubricants of equal quality.
FRONT AXLE
²
C205F - MoparT Gear Lubricant 75W-90
²
9 1/4 AA - MoparT Synthetic Gear Lubricant 75W-90
²
9 1/4 AA EL- MoparT Synthetic Gear Lubricant 75W-90
REAR AXLE
²
9 1/4 - MoparT Synthetic Gear Lubricant 75W-140
²
10 1/2 AA - MoparT Synthetic Gear Lubricant 75W-90
²
10 1/2 AA EL- MoparT Synthetic Gear Lubricant 75W-90
²
11 1/2 AA - MoparT Synthetic Gear Lubricant 75W-90
²
248RBI - MoparT Gear & Axle Lubricant SAE 90
NOTE: Trac-Lok
T differentials require Limited Slip Additive in the lubricant. Trac-Rite™ / Trac-Rite EL™ differentials
DO NOT require Limited Slip Additive.
MANUAL TRANSMISSION
²
NV5600 - MoparT Manual Transmission Lubricant
²
NV4500 - MoparT Synthetic 75W-85 Manual Transmission Lubricant
²
Getrag 238 - MoparT ATF+4 Transmission Fluid
²
G 56 - MoparT ATF+4 Transmission Fluid
² T-56 - MoparT Synthetic 75W-85 Manual Transmission Lubricant
Old Apr 21, 2010 | 06:48 PM
ramhunter9's Avatar
ramhunter9
ok break that down in quarts lol . front is what and rear is what ?? and do 75-90 in all or 75 -140 in all .... if i had a book this would be easier i would look it up , but i dont and im getting 10 different stories on the 2500
