Hesitation on cold
Old Dec 22, 2003 | 09:19 PM
chadthelad's Avatar
chadthelad
Default Hesitation on cold
my 03 quad 5.7 does this 2 not all the time just here and there the service guy told me its the nature of the hemi something to do with the 2 spark plugs per cylender lol what a joke yea i told him its probably got a loose mufler bearing to some ofthese service guys will say anything to get you to just drive away
Old Dec 27, 2003 | 05:24 PM
mopowrmike's Avatar
mopowrmike
my 04 quad hemi does thison the cold mornings. turn the truck on put it in reverse and it sorta hesitates when you give it gas
Old Sep 24, 2004 | 04:27 PM
awlehde's Avatar
awlehde
Default RE: Hesitation on cold
I have a 97 dodge ram, and when i go out to start it after not drivin in a few hours it hesitates to start pretty bad. it happens every time, but if i start it, shut it off, then try to start it again, it starts up rite away. it even starts fine if i turn the key to where it trys to start, then let go, then turn it again, it fires rite up. and sometimes when i start it, before i shift into drive, it idles rough. does anyone know what i could do to fix this?
Old Mar 25, 2011 | 12:39 AM
eveey's Avatar
eveey
I had the same issue with my '04 5.7 Hemi, but would do it more below 50F.
I replaced the EGR valve ($40 O'Rielly's) You have to do a computer reboot or will continue acting up.
1. Remove #23 fuse
2. Turn key to on (Not Start)
3. Wait for lights to go out
4. Turn key to Start and hold until 2 beeps. (about 10sec)
5. Reinstall fuse and start, 1st time it wont respond, 2nd time will start.
Hope this fixes your issue.
Old Mar 25, 2011 | 06:29 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
^^^ You do realize this thread was started back in 03 and ended in 04 right?
