4.7 noise
Old Mar 24, 2011 | 07:06 PM
bam2880's Avatar
bam2880
Default 4.7 noise
hi i have a 2005 dodge ram with the 4.7 and i have a noise on cold start up but gets quieter when the engine warms can anyone tell me what this is and describe what it sounds like if i have and exhaust manifold leak
Old Mar 24, 2011 | 07:35 PM
MoparMan1991's Avatar
MoparMan1991
If it was an exhaust manifold leak I don't think it would go away as the engine got warmer. It would help us greatly if you could describe to us what the noise sounds like.
Old Mar 24, 2011 | 07:53 PM
bam2880's Avatar
bam2880
it sounds sort of like a knock
Old Mar 24, 2011 | 08:02 PM
bam2880's Avatar
bam2880
can anyone describe what an exhaust manifold leak sounds like and if it raises with rpms
Old Mar 25, 2011 | 12:38 AM
MoparMan1991
Well I would be willing to bet that an exhaust manifold leak sounds like an exhaust leak. And since more exhaust is created at higher RPMs, then yes, it would get louder as the RPMs increase.
Old Mar 25, 2011 | 06:31 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
If you think you have an exhaust leak at the manifolds then go out there and check the bolts to make sure all are tight and none are broken. Then you will know for sure.
