how can i raise the front end
Old Apr 26, 2010 | 12:59 PM
OlDirtyJohn's Avatar
OlDirtyJohn
Originally Posted by Shiloh 24
As for the OP read what Hammer said, you can't really go any higher than you are now because your CV's are gonna just get obliterated. Just put a smaller block in the rear and uncrank to t bars until level.
ditto
Old Apr 28, 2010 | 05:09 PM
jose13b's Avatar
jose13b
ok but i like how high it is in the back so high do i raise the front 2 inches
Old Apr 28, 2010 | 05:21 PM
HammerZ71's Avatar
HammerZ71
YOU PUT EVERYTHING BACK TO STOCK AND YOU GET A SUSPENSION LIFT or YOU PULL THE REAR BLOCKS, DROP THE CRANK BACK TO DEAD LEVEL AND YOU GET A BODY LIFT!!!
There is no free lunch... You can crank the bars to dead level with a stock rear or get LEVELING keys to level it, but that's it!!! Otherwise say bye-bye to the CV axles and your other front end suspension components (tie rod ends, ball joints, etc) will wear and become unstable very fast.
If you have 3" blocks in the back, that means your rear is sitting 5" higher than the front at stock level. Unless you install a suspension lift or body lift level kit combination, THERE IS NO SAFE WAY TO GET THE FRONT END THAT HIGH!!!
Old Apr 28, 2010 | 05:25 PM
jose13b's Avatar
jose13b
is this the keys
http://shop.skyjacker.com/product.php
Old Apr 28, 2010 | 05:27 PM
Shiloh 24's Avatar
Shiloh 24
Originally Posted by jose13b
Keys are only gonna make it to where you can screw your CV's even more with the angle on the t bars. If you want higher you gotta pay to go higher, there is absolutely no way around it what so ever. ACCEPT IT!
Old Apr 28, 2010 | 05:29 PM
jose13b's Avatar
jose13b
thanks
