What is the little radiator?
Old Apr 25, 2010 | 11:57 PM
91StealthES's Avatar
91StealthES
Originally Posted by ramhunter9
just drive down hear ill do it !!
I have a feeling you are pretty far south.
I am in the northwest suburbs of Chicago.
Thanks for the offer though.
Looks like a 10 minute job.
Do I need to drain all the fluid and refill, or can I just clamp the hoses?
Old Apr 26, 2010 | 12:55 PM
OlDirtyJohn's Avatar
OlDirtyJohn
might as well swap all the PS fluid out while you are in there. it isnt much. quart or two maybe. just point the hoses into a bucket and crank the wheel back and forth a couple times. connect your new cooler, and top it off. crank back and forth a couple more times, and top back off.
thats what i would do at least.
edit: use ATF+4 for PS fluid.
Old Apr 26, 2010 | 07:28 PM
91StealthES
20 dollar part from PepBoys and it includes hoses.
70 dollars from dealer.
Any issues to expect with PepBoys part or should I pony up for OEM?
I have yet to check eBay for OEM parts.
Old May 28, 2010 | 04:22 PM
91StealthES
Hi guys,
I bought a Universal Power Steering Cooler yesterday from O'Reilleys because PepBoys now tells me it is now a dealer only part. $24 after taxes.
I think the dealer wanted $90 or something for the cooler. I have no problem paying that if the Universal won't fit/work properly.
Will I have any issues with this Universal cooler?
Anything specific I should do when I remove it, other than drain all the fluid by turning the wheel back and forth a few times with the hose unclamped?
I plan to perform this tomorrow morning.
Thanks,
J
