help me with removing antenna grille and emblems
Old Apr 25, 2010 | 05:20 PM
Brado34's Avatar
Brado34
Default help me with removing antenna grille and emblems
Alright.. so far i have the tails blacked out..
im in the process of putting back together my headlights after repainting them deeper into the chrome.. the only problem is my baking pan melted a hole in my headlight! good thing it was on the back i guess im just going to have to patch it back together.
i want to remove my emblems antenna and grille..
the antenna and grlle i plan on painting but how the heeck do i get em out!
i tryed 2 flat head screw drivers on the 3 indented ring at the bottom but i cant get it off..
Old Apr 25, 2010 | 05:24 PM
rocket23's Avatar
rocket23
everthing you need is in the diy section imo. just checking....sorry....
Old Apr 25, 2010 | 05:26 PM
Matt99's Avatar
Matt99
your grille has some 10mm bolts/nuts holding it on the brace(at least 06-08) I think about 10-12
The antennae has the three prong nut on the top (I used a pair of vice grips/rag but there is a special tool) and then it all comes apart
Old Apr 25, 2010 | 05:29 PM
rocket23's Avatar
rocket23
I really thought you were gonna link up your debadging diy thread with that advice. That was a great thread matt99.
Old Apr 25, 2010 | 05:30 PM
BEAR's Avatar
BEAR
The antenna I can't help you with cuz I ain't never wanted to take mine off but a few members on here have so maybe they will chime in on that. For the grill, it's mounted to a frame that is bolted to the hood. All you have to do is raise the hood and look up at the back of the grill and you will see the bolts/nuts you need to remove. For the badges just get some good fishing line and slide it behind the badge and start sawing. The line will cut the adhesive that holds the badge on. If you do a search I'm sure there are a few DIY's on Debadging.
Old Apr 25, 2010 | 05:36 PM
Matt99's Avatar
Matt99
I have too much school stuff on my comp, I dont have all the links saved...
OP, look in the DIY section, I did a debadging deal. And I also had a schematic for removing the antennae that I posted in silvers thread. I cant find it either
Old Apr 26, 2010 | 03:46 PM
Brado34's Avatar
Brado34
so i just looked at the grille.. only way to get it off would be to break a few plastic pins..
Old Apr 26, 2010 | 04:20 PM
JoeHemi's Avatar
JoeHemi
Do what? You trying to remove just the inserts or the entire grille itself? Either way, you need to remove those 10mm bolts on the bottom and top on the grille. Then it pulls right off. To get the inserts out, you need like a hard tip (i used a really small torx bit) and you need to pop out the center pins of each retainer plug that holds the inserts onto the grille.
Old Apr 26, 2010 | 05:03 PM
Brado34's Avatar
Brado34
just the inserts my man.
( the chrome part)
i got the antenna off and painted but i cant get the ram head off..
maby because its on a bug deflector?
