post level alignment question
Old Apr 26, 2010 | 09:26 AM
southernbnb's Avatar
southernbnb
Default post level alignment question
so how vital is it to get an alignment after leveling my truck? i know i need to do it asap but could it go a week without messing anything up? or would it ride like total azz?
Old Apr 26, 2010 | 09:40 AM
Shiloh 24's Avatar
Shiloh 24
My drove like a hunk of sh*t after I put it in, course that was the same time my rack went bad. I wouldn't recommend putting any hard miles on it like that but to and from work if it's close should be ok for a few days.
Old Apr 26, 2010 | 09:45 AM
HammerZ71's Avatar
HammerZ71
I'd do it pretty soon. I had mine done the day after I did the suspension lift and it drove like sh*t just taking it there. But that was 4" of lift and a host of new components.
I was tempted to wait after putting the 2" coil spacers on the Jeep as it tracked true going down the road and drove fine, but I took it in about 5 days after having it done and even though it was relatively straight you wouldn't believe how bad it was cocked bottom in. It would have completely worn the inside 1/3 of my tread in no time.
Even if it seems to be driving fine, get it in and get it done. People just need to swell up and acknowledge that the alignment is a necessary step in EVERY front end suspension change...
Old Apr 26, 2010 | 09:50 AM
southernbnb
thats what i thought the answer was going to be. guess the level is going to have to sit in the box for another week or two. oh well.
Old Apr 26, 2010 | 10:06 AM
hoss67's Avatar
hoss67
^^^ yea alignments are EXPENSIVE!!!
Old Apr 26, 2010 | 10:09 AM
southernbnb
hoss - the really sad part is they are only like 75 bucks around here! im just tapped out!
Old Apr 26, 2010 | 10:16 AM
hoss67's Avatar
hoss67
75 bucks! thats more than mine hahahahaha mine was 50 bucks
Old Apr 26, 2010 | 10:17 AM
hoss67's Avatar
hoss67
i still think 50 bucks is to much for a re alignment
Old Apr 26, 2010 | 10:24 AM
rocket23's Avatar
rocket23
My two cents; southern, the toe in and out willnot be affected, however the cast and camber will be all f&^ked up. As the truck sits stock the wheels are on an even plane. Asthe trucks front end lifts, the tires end up casting out from the top creating an alignment.
Old Apr 26, 2010 | 10:32 AM
Matt99's Avatar
Matt99
yea I think youd be alright for a week or so, I was....it sucks and your tires scream if you turn at full lock but if you have the stockers and dont drive too much itll be fine
