How would i mold a cowl to oem hood?
Old Apr 27, 2010 | 10:27 PM
Brado34's Avatar
Brado34
Default How would i mold a cowl to oem hood?
So on ebay for like 80 bucks i found a super sick hood cowl.
I also found a 25$ white hood on kijiji with a little dent
i figure i may as well try to make a super sweet good outta it...
sand the crap outta the hood - what grit paper would i use?
then pretty much just bondi the cowl ontop of the oem hood..
how would this hold up? would the cowl blow off from driving fast?
what would i have to do to prevent water from going in the back side?
Old Apr 27, 2010 | 10:28 PM
oefootball_70's Avatar
oefootball_70
screw the thing down with wood screws and bondo over the top.
Old Apr 27, 2010 | 10:42 PM
Brado34's Avatar
Brado34
i want it to look like this
http://www.techhoods.com/Ram_Air_Hoo...Hood_Steel.jpg
like a legit company made it. i dont even know where the screws would do...
tell you the truth i dont even know where to start.. but wood screws sounds a little funny
Old Apr 27, 2010 | 10:44 PM
oefootball_70
it was a joke. red neck style
I would use 3m double sided tape and then you wanted a better look and you are going to paint then you might was well use a little bondo. IDK. Thats how I would go about it.
Old Apr 27, 2010 | 11:59 PM
Ice-Forever's Avatar
Ice-Forever
yeah those bee scoops u can buy are held on by 3mm tape and those hold on fine as far as I know...
Old Apr 28, 2010 | 12:13 AM
JoeHemi's Avatar
JoeHemi
whats the cowl made out of? Generally fiberglass and steel dont like each other. If you found a metal cowl, just weld it on, grind it down, then fabricate it to your liking.
