Grease
Old Apr 27, 2010 | 11:06 PM
Steve Ruddy's Avatar
Steve Ruddy
Default Grease
What type of grease are you all using and can it be used for the ball joints and universal joints?
Old Apr 28, 2010 | 12:52 AM
dirtydog's Avatar
dirtydog
Moderate User
I'd only reccomend Synthetic grease with a high melting point.
Not sure what year you got, but most of the newer trucks have non greasable fittings.
You can use the same grease for all if you have greasable joints.
Old Apr 28, 2010 | 07:34 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Well i assume you have aftermarket BJs or a 2500 because the 1500 BJ has no fittings. In fact there are no fittings on anything for a 1500 with OEM parts. Only aftermarket parts have fittings.
Old Apr 28, 2010 | 07:43 AM
HammerZ71's Avatar
HammerZ71
I greased my door hinges the other day cause they were squeeking. But thats about the only part on a 1500 I've found to grease, LOL...
Old Apr 28, 2010 | 12:09 PM
Steve Ruddy
__________________
Sorry I just updated my profile with truck info. I have an 04 2500 4x4. What do you think about this http://www.amsoil.com/storefront/gwr.aspx or is there something better. I imagine I will be squirting the undercarriage off with a pressure washer from time to time.
Old Apr 28, 2010 | 12:56 PM
stenerson's Avatar
stenerson
front passenger side tie rod end on my 2004 has a grease fitting. The chilton manual shows it with one also. Strange though that the driver side one doesn't.
