2004 Dodge Ram 1500
Old Apr 28, 2010 | 07:53 PM
sap720's Avatar
sap720
Default 2004 Dodge Ram 1500
Hi,
I have a 2004 Dodge Ram 1500 2WD with a 4.7 Magnum and was wondering if you could install a front crank seal with out removing the timing cover.
Old Apr 30, 2010 | 07:24 AM
HammerZ71's Avatar
HammerZ71
moving to 3rd Gen...
Old Apr 30, 2010 | 07:37 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
They make a Miller installer tool for that but IDK if it has to be pulled. The 5.7 does so I would assume the same would be true with the 4.7 but Im not certain.
Old May 20, 2011 | 09:41 PM
Rick Ross's Avatar
Rick Ross
So the seal is pulled on a Hemi?? I am gonna change mine tomorrow cause its leakin. Just wonderin if I have to pull the timing cover off too??? But if I dont, then the better. I only got the seal at the dealership, I shoulda asked there.
Old May 20, 2011 | 11:06 PM
chambers's Avatar
chambers
The front crank seal can be pulled and replaced w/o removing the timing cover on the 4.7 and 3.7. After you remove the pulley, you just carefully pry the old seal out w/ a screwdriver or use a seal puller. Then you can use a large socket to tap the new one in, heating up the pulley in an oven and greasing it where the seal fits around it will make it easier to get on after the new seal is in.
