Replace Engine Oil Base Pan
Old Apr 30, 2010 | 09:33 AM
glenn.d.smith's Avatar
glenn.d.smith
Default Replace Engine Oil Base Pan
Anybody know if this can be done by a diy'er? I've heard different opinions from "It's a piece of cake" to "you have to raise the engine"! I wanna do an oil change and I think I've pressed my luck long enough with the stock pan - flaking rust everywhere!
Thanks
G
Old Apr 30, 2010 | 12:18 PM
glenn.d.smith
No takers eh? I know I seen a thread on this a while back but I haven't been able to find it. It may be one of those things where it looks easy but not so when you start to do it. I think I have seen something on another forum where somebody said you have to remove the front cover to release the pan - that seems pretty crazy!
Old Apr 30, 2010 | 01:24 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I know I can do it but then I also have all the tools I need to do it if I needed to. IDK the skill level you have but I have the confidence in you that you can manage it. You do not need to remove the front timing cover but you do need to remove the 5 bolts holding the pan to the bottom of the front timing cover as well as the cross member.
Old Apr 30, 2010 | 02:47 PM
glenn.d.smith
Thanks WEED! That seems pretty straight forward to me. I'll have to spray a little wd-40 on those x-member bolts - maybe even have to heat the x-member too. I live in Atlantic Canada and we see ALOT of rust so bolts are sometimes tricky to remove in one piece As a matter of fact, I just recently took off the front tow hooks after letting them bathe in rust check for a bout a week!
Old May 2, 2010 | 09:37 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
If you have any issues just LMK.
