Newbie please help
Old Apr 30, 2010 | 10:53 PM
PENDRISS's Avatar
PENDRISS
Unhappy Newbie please help
Just got a 2005 Ram 1500 and replaced rear sensor because abs/parking brake light was on, now it goes off when the vehicle is turned off then on and comes back on and stays on after with a code of erratic signal in rear abs sensor, which was the same code before the new sensor was put in. All connections are dry and debris free, PLEASE HELP! Thanks.
Old May 1, 2010 | 01:26 AM
lxman1's Avatar
lxman1
Site Moderator
Welcome to the forum!!
Trace the wiring back some and look for any bad spots. Might get lucky, hard to say.
Old May 1, 2010 | 02:34 AM
mopar6spd's Avatar
mopar6spd
Could be a wire grounding out.. Check out the harness like lx stated.
Old May 1, 2010 | 07:30 AM
PENDRISS's Avatar
PENDRISS
Is there a certain spot to look that is more common than another, I've checked under the hood and didn't see anything and all looks well by the diff. Thanks for the quick replies!
Old May 1, 2010 | 09:51 AM
BEAR's Avatar
BEAR
just take your time and trace it all the way back. Good luck.
Old May 1, 2010 | 09:57 AM
rtmtrrdr's Avatar
rtmtrrdr
You might also have to reset the comp I think.I mean clear the code
Old May 2, 2010 | 09:49 AM
PENDRISS's Avatar
PENDRISS
Thanks for the help guys, I traced the wiring and can't find a exposed wire/broken wire and also have reset the computer; I'm leaning towards a module, found one off an 04 w/only 44k on it for $50 shipped, I'll throw that in and hopefully all will be fixed One question though is there a connector/harness right under the driver's side door that is open to the elements? Looked like the wires are insulated but if there were a problem that is where I would see it as being.
