I just installed airbag helper springs
Old May 1, 2010 | 06:10 PM
Bent's Avatar
Bent
Default I just installed airbag helper springs
I have a mid-sized 5th wheel camper, Gross is approx 7800 pounds, which is borderline for trailer weight the way my 1500 QC 4x4 is equipped.
I put a set of Ride-Rite bags in, which include Firestone airbags and almost all of the hardware...
They intended for me to use individual airlines, but I wanted to "T" the lines and use a common air inflater valve. I'm aware that the air could end up transfering from one side to the other when my load is tall - resulting in sway, but I'll soon be putting a hellwig anti-sway bar, so that won't be an issue.
I'm impressed with this kit, it seems to be built quite well.
Old May 1, 2010 | 06:13 PM
stenerson's Avatar
stenerson
A friend of mine is a contractor and is a big fan.
Old May 1, 2010 | 06:23 PM
AF_HEMI's Avatar
AF_HEMI
hope you never plan to lift the truck...
Old May 1, 2010 | 06:26 PM
dirtydog's Avatar
dirtydog
Moderate User
Makes no difference with most of the kits since they ride on the leaf spring. As for kits like mine that ride over the axle, they make spacers to raise the bags up as well. I'd have a hard time believing that he would raise up the suspension more than 3" while trying to pull a 5th wheeled trailer around???
Old May 1, 2010 | 07:49 PM
Bent's Avatar
Bent
I have no need to lift it, it never goes off-road - I have an ATV for off-roadin', a boat for fishin' and a snowmobile for sleddin'.
And now, I have a 26' 5th wheel for campin'
Old May 1, 2010 | 07:55 PM
Bent's Avatar
Bent
Hopefully a fan of the air helper springs and not of me...
(But I am a pretty good guy - none the less.)
