2007 ABS and Brake light
Old May 1, 2010 | 10:43 PM
johnnietcm's Avatar
johnnietcm
Default 2007 ABS and Brake light
I have a 2007 Dodge 2500 5.9lt diesel. Recently the ABS and Brake light come on and off intermittently. What is this caused from and can it be reset. When cycling the ignition no error code is displayed.
Old May 1, 2010 | 10:50 PM
Denniss66's Avatar
Denniss66
well as much as i would like to help i got the same problem on my 03 1500 hemi. recently i did axle seals and had the abs sensor out of the hub so im pretty sure my abs sensor got wrecked in the process.
Old May 1, 2010 | 10:52 PM
dodg360's Avatar
dodg360
Mine does the same thing on my 04 4.7. I just turn the truck off, restart, and Wah lah! Lights are off. Gremlins!!
Old May 2, 2010 | 01:51 AM
freestyledude's Avatar
freestyledude
Check the rear differential sensor. I had this problem after I did my axle swap. New sensor and I was golden! Might even be able to just clean it off.
It's on the top of the diff, just undo the nut, pull out the stud, and carefully pry it out
