temp. question
Old May 6, 2010 | 09:38 PM
RedTruck-VA's Avatar
RedTruck-VA
Originally Posted by rebelroot
checked the radiator for hot and cool spots and it was just fine..... when the temp gauge starts to move past halfway i can turn on the heat and it will go back to normal.... what can it be?
Running the heater and having it cool back down is normal. Shows you are right on the edge of seriouly over heating. From what you have stated, my guess would be restricted flow. Which comes to basically the thermostat or radiator.
Old May 7, 2010 | 09:38 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You guys know what I always say about 4.7s and overheating issues, warped/cracked heads and bad head gaskets
Old May 9, 2010 | 10:31 PM
LA BOY's Avatar
LA BOY
May want to check fan clutch, I have a 05 and have had to replace it twice
Old May 9, 2010 | 10:41 PM
Denniss66's Avatar
Denniss66
you should have got an electric fan put on instead.
Old May 10, 2010 | 09:29 AM
rebelroot's Avatar
rebelroot
how do u check your fan clutch
