AC Condensor fan not coming on
Old Aug 9, 2015 | 05:20 AM
  #21
abarmby's Avatar
abarmby
Are the electrical connections to the motor ok?
Not corroded or damaged?
The contacts in the conector must obviously be sound.
Wiggle the connector and wiring and see if you can start or stop the condenser fan, which would indicate poor contacts or open circuit cabling.
Al.
Old Aug 10, 2015 | 10:43 AM
  #22
sgarber13's Avatar
sgarber13
We did check that, but we will check again. The compressor is short cycling also.
Old Aug 10, 2015 | 11:43 AM
  #23
abarmby's Avatar
abarmby
The compressor will short cycle if the ac condenser fan isn't running.
At this point if your new fan isn't running and you are sure there's no problems with the electrical connections, om afraid it's a dealer/ac shop Visit.
Al.
Old Aug 10, 2015 | 01:10 PM
  #24
TejasMtnBiker's Avatar
TejasMtnBiker
was there any front end damage to your truck at one time?
Old Aug 10, 2015 | 05:29 PM
  #25
dodgesonly's Avatar
dodgesonly
This may not work in your case, as the symptoms are not quite the same, as you (the OP) stated when you tapped on the AC condenser fan motor, then the fan sputtered to life. But in my own condenser fan troubles recently (2000 Dakota Sport), my problem was the low pressure cut off switch located on the drier bottle. May be located differently on your truck. I put a jumper wire on the plug in, bypassing that switch, and now the condenser fan operates normally. May not be a fix for your current problem, but I thought I mention it just in case it helped.
Old Sep 6, 2016 | 02:00 AM
  #26
Wrecker97's Avatar
Wrecker97
Originally Posted by abarmby
Yes there is. Give the AC condenser fan a sharp tap with a small hammer, with the AC set to on and the engine obviously running.
If it starts to spin, it's the fan.
Do that or, spin the fan by hand to give it a "kick on". It should spin, but will have very little torque behind it.
Usually, the brushes in the motor wear out.
I rebuilt this motor in my truck and she's been great, for about two years now.
I think there's usually a few new ones on e-bay for sale.
Don't run the AC with this fan not working. High pressure will build up to high temps due to not being cooled. It could permanently damage your AC system.
Al.
So I just replaced my entire AC condenser fan and Motor everything except the coil how will I know I fixed the problem without code reading will it turn off by itself?
Old Sep 6, 2016 | 02:01 AM
  #27
Wrecker97's Avatar
Wrecker97
Originally Posted by Wrecker97
So I just replaced my entire AC condenser fan and Motor everything except the coil how will I know I fixed the problem without code reading will it turn off by itself? 2004 Dodge Ram 1500 4.7 v8
I really need to know
Old Jun 1, 2018 | 09:01 PM
  #28
Rocky wyatt's Avatar
Rocky wyatt
Al.
Thanks Al, you just saved me from a large bill at the stealership...I just could not figure this fan out...but with a little love tap from my trusted hammer the fan seen the light...I also will be getting a replacement...thank you for sharing your knowledge on this matter, I appreciate all of you that contribute to this forum!
Old Jul 17, 2019 | 06:45 PM
  #29
Stephen Tubbs's Avatar
Stephen Tubbs
Default I replaced fan assembly. Now condenser fan runs when I turn on a/c but pump won't kic
Originally Posted by weedahoe
Al. Nice tip on kick starting the fan. I would just hot wire mine to the battery to check it.....LOL
kicon
Old Jul 25, 2019 | 11:34 AM
  #30
theuscfan04's Avatar
theuscfan04
I just replaced my fan a couple of weeks ago and it fixed my problem. Fan was $30 from Autozone and about a 45 min job.
