curroded plug??
Old May 6, 2010 | 08:04 AM
rocket23's Avatar
rocket23
If you had antifreeze in just one cylinder, You would have a smoke show everytime you let up on the gas peddle, out the exhaust pipe btw. It happened to me.
Old May 6, 2010 | 08:10 AM
maverick_124's Avatar
maverick_124
i only get a blue-ish smoke when i give it gas..but not all the time just when she idles for 30 seconds at only at running temp..the longer it sits the bigger the puff of smoke and the more blue/white it is..
and my mods are airram power wire, stright pipes, and cone filter
and i gap them with my little circle gapper thing that you can get from the auto store
Old May 6, 2010 | 08:15 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I would change new plugs and run them for a few thousand miles and pull and check them to see where you are at.
Old May 6, 2010 | 08:16 AM
rocket23's Avatar
rocket23
does'nt sound good. How many miles on her? It sounds like a blown piston,did you do a compression test on that cylinder? That will tell you if the rings are good In that cylinder or at least they are all the same. ( the other cylinders).
Old May 6, 2010 | 08:17 AM
rocket23's Avatar
rocket23
Hey weed, your up early sorta.
Old May 6, 2010 | 08:27 AM
maverick_124
i dont have a tester...and no one i know has a tester...
Old May 6, 2010 | 08:37 AM
rocket23's Avatar
rocket23
Some one in Florida has one, they re not that expensive. auto zone napa, to name a few.
Old May 6, 2010 | 09:00 AM
cwboyjohnny24's Avatar
cwboyjohnny24
"blue-ish" smoke is not a good sign. In my experience, that's not coolant that's oil. You will have some pretty extensive repairs coming soon my friend.
Old May 6, 2010 | 09:06 AM
maverick_124
welll im thinking about cracking the motor and only changing the piston rings...
Old May 6, 2010 | 09:12 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
6am every morning brother. Sun to Sat.
