Old Aug 10, 2015, 04:59 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Cooling System Guides
Print Wikipost
Flushing the Radiator?
Old May 5, 2010 | 09:22 AM
Dodge_Farmer1095's Avatar
Dodge_Farmer1095
Default Flushing the Radiator?
Hey all here at DF, got a question about flushing my radiator on a 07 dodge 1500. And I've got a couple mixed responses on when... My manual says 3yrs/60k and the dealer said 5yrs/90k. Talked to a shop and they said 3yrs as well. But the shop price was a little a steep I thought, so i was just going to do my self. Any fancy things that need to be known or is it as simple as older rigs(which i doubt) but just figured I'd some people who own one instead of asking someone who sells a product.
Old May 5, 2010 | 10:37 AM
superdak05's Avatar
superdak05
when flushing the radiator, flush the whole system, heater core and all. you will need to find the heater core inlet tube and remove it. flush backward removing all the crude and debris if any. remove the bottom rad hose so all the crap flows into a bucket. and fill with the mopar recommended fluids, and you should be good to go
Old May 5, 2010 | 10:53 AM
KingsMan's Avatar
KingsMan
I've always preferred to drain mine every two years regardless of miles. Coolant can "wear out" eventually and lose its effectiveness.
Unless you're using pre-mixed antifreeze, make sure you use distilled water along with your antifreeze when you refill it. It's only about a buck per gallon. The minerals in tap water are reactive to the aluminum in your motor/radiator and can cause corrosion problems.
Old May 5, 2010 | 11:15 AM
cwboyjohnny24's Avatar
cwboyjohnny24
That's pretty much how I did mine. I got the Prestone kit at the auto parts store. It comes with a tee you splice into the heater core tube. It has threads to put your hose onto. After you're done you put the cap on it and leave it there. Then you have it and can do a flush easily whenever the truck's ready for it.
Here's the one I bought.
http://www.autozone.com/autozone/cat...l+Radiator+Kit
Old May 5, 2010 | 11:36 AM
FireFighter's Avatar
FireFighter
From: The old famed Gen3 Broken Valve Spring Thread - https://dodgeforum.com/forum/3rd-gen-ram-tech/237316
Also, take out your old T-Stat and reconnect the hose before flushing as well as letting the block drain from the drain plugs, there are two (2).
Make sur you purge the system 100% of all air. Lastly, have fun!
