? for 3rd gen guru's
Old May 8, 2010 | 07:49 AM
olyelr's Avatar
olyelr
Default ? for 3rd gen guru's
Hey fellas, I have a question for all the 3rd gen guru's.
What is the difference between the 1500 mega cab and the 2500 mega cab? It appears the half ton has the same axles, but I'm not for sure. And what about the rest of the drive-train (tranny, transfer case, etc.), is that the same/different? Or is it just the spring rates?
Any help is greatly appreciated. Or even a link to facts about this sort of information.
Thanks in advance,
Brandon
Old May 8, 2010 | 08:29 AM
SMKNRAM's Avatar
SMKNRAM
the way i understand it is they are the same! Both are built on the 3/4 ton chassis same axles and drivetrain, just a different classification for licensing.
Old May 8, 2010 | 09:16 AM
rocket23's Avatar
rocket23
The mc was / is put on the 2500 chasis. which means I haven't looked at the bolt pattern when I was At the dealers. sob. That would of answered your question.
But then again ramhunter is always complaining of the three extra bolts he has, So the mc is a 2500 in a stretched out 1500's body. imo
Old May 8, 2010 | 11:17 AM
dirtydog's Avatar
dirtydog
Moderate User
As far as I knew the MegaCab is only made in the 1500 series trim but is still built on the 2500 series frame. The truck is very long and heavy and therefore has reduced towing/hauling capacities so it canot tow near as much as a normal 2500 but instead has the capacities of only a 1500.
So, it has 2500 frame, brakes, lugs, rear end....etc... 8-bolt lug pattern.
Old May 8, 2010 | 02:53 PM
Got_Hemi44's Avatar
Got_Hemi44
You can get a 2500 Mega. It's a CTD.
Old May 8, 2010 | 02:59 PM
xfeejayx's Avatar
xfeejayx
3rd gen Ram, Newbies
If the only difference between a 2500 & 1500 is the ctd the 1500 should have a higher tow rating.
I have to agree, a 15MC is a 25
Old May 8, 2010 | 03:13 PM
Mega-Hemi's Avatar
Mega-Hemi
2500's have stiffer front springs, stiffer frame(so I've heard??) and 5 rear springs, 1500 has 4 rear leaf springs. Other than that, they are identical. The 2500 is still available w/ the HEMI. Not only the CTD.
Old May 8, 2010 | 07:23 PM
rocket23's Avatar
rocket23
That is still one big a$$ truck ! Anybody seen the price tag on these bueaties, Wow! But still cheaper and better imo, than a furd 250 or larger.
Old May 9, 2010 | 08:13 AM
olyelr's Avatar
olyelr
Well OK, I do know for sure the 1500 MC has the sam AAM axles with 8 bolt hubs. I also know that you can get the MC in a 3/4 ton and 1 ton, even a dually (short box one at that). And yes, you can get a diesel in the 3/4 ton and 1 ton too.
The main reason I ask is I am looking at purchasing a newer truck, possibly a MC. And I know I cant afford a diesel (even if it has 150k miles on it hahahha), but I also said I would never purchase a half ton again after owning this one. But, since I would be getting a hemi anyway, and the half ton appears to be just as stout as the 3/4 ton (drive-train wise), I figure why not. Plus they are quite a bit cheaper. And for those who were questioning price, I have found some half ton 06's for under $20k, but most are barley under 100k miles. For one with 50k miles they are closer to the $25k.
So anyway, no real facts yet, but a lot of "pretty sures" that are matching mine too .
I cant believe how hard it is to find a built sheet of some sort on these trucks. Damn.
Old May 9, 2010 | 08:22 AM
Mega-Hemi's Avatar
Mega-Hemi
Here is my Build Sheet:
Thank you for contacting the Chrysler Customer Assistance Center,
regarding your 2006 DODGE RAM 1500 SLT MEGA CAB 4X4,
VIN#*****************.
We are pleased to provide vehicle build information per your request.
According to our records, your vehicle was equipped from the factory
with the following:
M9D5 Cloth 40/20/40 Prem Bench Seat
ADA Light Group
ADB Protection Group
AHC Trailer Tow Group
APAS Monotone Paint
A85P 5.7L ENG (EZA)/5SPD A/T 5-45RFE(DGQ)
BAZS 136 Amp Alternator
BCQP 750 Amp Maintenance Free Battery
BRTS Anti-Lock 4-Wheel Disc Brakes
CBEP 40/20/40 Split Bench Seat
CGDS Front Height Adjust Shoulder Belts
CGS Supplemental Side Air Bags
CG1S Next Gen Multistage Front Air Bags**
CJ2P Supp. Side Curtain Frt/Rr Air Bags
CKES Front Seat Area Carpet
CLES Front & Rear Floor Mats
CSPS Passenger Assist Handle
CSXP Rear 60/40 Split Folding Seat
CUMP Mini Floor Console
CUSS Overhead Console w/Trip Computer
CU3S Behind the Seat Storage / Bin
CVHP Front Center Seat Cushion Storage
DGES All 5-Speed Automatic Transmissions
DGQ 5-Spd Automatic 545RFE Transmission
DHAP Lock-Up Torque Converter
DH3S Elec Shift-on-the-Fly Transfer Case
DJQS 5,200# Front Axle
DMES 3.73 Rear Axle Ratio
DRWS 10.50 Rear Axle
DSA Anti-Spin Differential Rear Axle
EAGC All Gas Engine
EZA 5.7L V8 HEMI Engine
GACS Tinted Glass Windows
GFE Rear Power Sliding Window
GNCP Sun Visors w/Illum Vanity Mirrors
GNKP Rear View Auto Dim Mirror
GNMS Passenger Side Sun Visor w/Mirror
GTSS Power Heated Mirrors, Fold-Away
GVBC All Vehicles W/Power Mirrors
GWA Power Sunroof
GXMS Remote Keyless Entry
GXXS Sentry Key Theft Deterrent System
HAAS Air Conditioning
HGFS Floor Tunnel Insulation
JAYS Instrument Cluster w/Tach
JBYS Instr. Panel Color Keyed Bezel
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JJAS Cigar Lighter
JJBS Dual Note Electric Horns
JJJS 12V Auxiliary Power Outlet
JPBS Power Locks
JPDS Power Windows, Driver One-Touch
JTHP Power 6-Way Driver Seat
K1XP STRIPE/BADGE/MOLDING/COLOR
K17 STRIPE/BADGE/MOLDING
LBCP Glove Box Lamp
LCLP Front Dome w/On/Off Switch Lamp $
LDAP Underhood Lamp
LMAS Halogen Headlamps
LNJ Fog Lamps
LPES Cargo Lamp
MBFS Bright Rear Bumper
MCMS Body Color Upper Fascia
MCTS Bright Front Bumper
MDAS Front License Plate Bracket
MFDS Bright Grille
MGAS Ram's Head Badge
MHAS Black Windshield Moldings
MTDS SLT Badge
MUSS 4X4 Badge
MWDS Removable Tailgate w/Caliper Latches
MXBS Front Air Dam
MXCP Front Bumper Sight Shields
NAA Federal Emissions
NBKP EVAP Control System
NFUS 34 Gallon Fuel Tank
NHBP Auxiliary Transmission Oil Cooler
NHMS Speed Control
NHNP Electronically Controlled Throttle
NMCS Heavy Duty Engine Cooling
NZDP Next Generation Engine Controller
PS2A Bright Silver Metallic Clear Coat
QS2S Bright Silver Metallic Clear Coat
RAAC All Radio Equipped Vehicles
RCDS 4 Speakers
RDDP Fixed Long Mast Antenna
XAP Power Adjustable Pedals
XBSS Pickup Box
XEAP Tow Hooks
XEFP Transfer Case Skid Plate Shield
XFHP Class IV Receiver Hitch
XFKP 7 Pin Wiring Harness
XFUS Trailer Tow w/4-Pin Connector Wiring
XME Under Rail Box Bedliner
YAAS Build To U.S. Mkt. Specifications
YG7A 2 Additional Gallons of Gas
ZCCP Spring - Left Front
ZKVP Spring - Left Rear
ZRBP Spring - Right Front
ZYVP Spring - Right Rear
Z7DS GVW Rating - 8510#
0A8A *** DESCRIPTION NOT AVAILABLE ***
1AAS U.S. Dealer Retail
135S Zone 35-Washington
2TGA Customer Preferred Package 2TG
26G Customer Preferred Package 26G
4KZP 4X4 Tracking
42EP Saltillo Truck Assembly Plant
5IFS DH-Vehicle Family
5I4S Four Wheel Drive (4WD)/(4X4)
5YFS Mega Cab
5ZES 6 FT. Cargo Box
5ZLS 1500 Series
594S Vehicle Order Tracking
6FD Paint Order Code
6USS U.S. Specifications Label
639S Pennsylvania Ship to State Code
939S Pennsylvania Sold to State Code
Thanks again for your email.
Sincerely,
Teresa
Customer Service Representative
