oil help
Old May 11, 2010 | 12:17 PM
badfish88's Avatar
badfish88
Default oil help
so about 4000 milers ago i switched to 5w20 amsoil semi synthetic. im goin on a 7 hr road trip in 4 days. so i checked my oil and it was a little low. well the guy i bought it from dont work with me any more and i cant find it in stores any were. would it be ok to add half a quart of something else?? if so, then what. also i was thinking of just goin to mobil one synthetic because of the covienience of it being in stores.
Old May 11, 2010 | 12:45 PM
Nothin'_but_trucks's Avatar
Nothin'_but_trucks
As long as you stay with the same weight and semi-syn. or full syn. then it shouldn't be a problem I would feel comfortable doing 6k on a semi-syn.
As far as switching to Mobil, that is fine but don't get tricked into thinking that Mobil smashes the rest because it simply doesn't. Most modern syn. oils all work great so might want to consider another brand. Pennzoil Platinum is another popular syn. that is cheaper than Mobil and more often can be purchased on store deals and it performs the same. Valvoline Synthpower or whatever the hell its called is another one, it performs well for about the same price BUT the Valvoline has a relatively empty add pack which would make me stay away from it only because of it having an equal price to M1 and PP but without the additives that those compared.
At the end of the day you can't go wrong with most modern synthetics just make sure to stay on top of your oil changes and you'll be fine.
Old May 11, 2010 | 01:18 PM
rocket23's Avatar
rocket23
A synthetic blend is part synthetic/and dino juice, nothing more. Adding the same viscosity wether reg,oil or full synthetic will not harm your motor.
I do have too disagree somewhat on the previous poster.Mobil one went up against all the major oil mfg's brands and beat them with thermal breakdown,foaming, and coating ability. The group that did this btw was in fact amsoil.Now why would a company tout another mfg's oil other than there own? Simple,b/c in this instance it was true. The amsoil challenge used all the major brands, and the only synthetic oil that stayed with amsoil or outperformed it in certain criteria was in fact mobil one.
Old May 11, 2010 | 04:13 PM
Nothin'_but_trucks
Your absolutely right. M1 did place second behind AMS on SOME of the tests. Some of the tests means that it did not on others, such as; four-ball wear - Motorcraft, cold crank viscosity - Quaker State, noack - Castrol, oxygen uptake - Motorcraft.
6 tests total, 4 of them M1 was beat by another brand.
How many times in the top 5 (not counting AMS):
Mobil 1- 6
Motorcraft- 4
Kendall- 3
Trop Artic- 3
Valvoline- 6
Pennzoil- 4
Castrol- 2
Quaker State- 2
I want to reiterate that M1 is a good oil, however, when you look at the price disparity of M1 and other brands compared to performance of M1 and other brands not much more performance is being purchased for the additional money.
http://www.amsoil.com/performancetes...veOilTest.aspx
Old May 11, 2010 | 04:42 PM
badfish88's Avatar
badfish88
so just stay with the same weight and ill be ok....................
Old May 11, 2010 | 04:50 PM
Nothin'_but_trucks
Yes, didn't mean to jack your thread
Old May 11, 2010 | 04:55 PM
Redone4x4's Avatar
Redone4x4
I sell amsoil but in a pinch i substitute mobil 1 as needed. Amsoil usually has to be ordered and cant be found on weekends, last minute, etc so mobile 1 is next best imo.
Old May 11, 2010 | 04:57 PM
Redone4x4's Avatar
Redone4x4
if you do that, then snag an amsoil filter to go with it. it will help in the long run and if go a lil over on your oil change its not such a big deal.
Old May 11, 2010 | 05:11 PM
JoeHemi's Avatar
JoeHemi
If you do get Mobil1, the best price in my area that I've found it for is at samsclub unless you find it on sale somewhere. It's $5.45 a quart at my sams.
Old May 11, 2010 | 09:50 PM
wyseguy77's Avatar
wyseguy77
Do an early change to full synth.
