Help identify plug under driver side dash please
Old 05-11-2010 | 09:39 PM
David Schmaus's Avatar
David Schmaus
Default Help identify plug under driver side dash please
I have a 2006 Dodge Ram 1500 SLT. I am trying to hardwire my Garmin Nuvi. Under the driver side dash there is a plug that isn't plugged into anything. I tested it and one of the wires is a 12 volt lead with the ignition on. Does anyone know what this plug is used for?
In the first picture I am pointing to where the plus is behind the dash
Here is the picture of the plug.
Thank you all for the help..
David
Old 05-11-2010 | 09:57 PM
Mega-Hemi's Avatar
Mega-Hemi
It is for the optional power pedals. There are probably 10 unused plugs floating around in your dash. Dodge uses the same wiring harnesses for their trucks, then adds accessories as they are built. I found 3 behind my stereo bezel.
Old 05-11-2010 | 10:06 PM
MikeHTally's Avatar
MikeHTally
Agreed. There's a smaller one under the wheel behind the knee bolster. Those are usually a good source for switched and unswitched power sources.
caliboy@heart's Avatar
caliboy@heart
Correct...power pedals.
Old 05-11-2010 | 10:17 PM
David Schmaus
Thanks guys. My next question was going to be if it would be a good source to power my gps.
Old 05-12-2010 | 12:39 AM
davb673's Avatar
davb673
Speaking of GPS installs, has anyone uncovered a vss wire behind the dash?
Old 05-12-2010 | 01:40 AM
mudkicker78's Avatar
mudkicker78
are you permanatly mounting your gps in the truck?
Old 05-12-2010 | 01:44 AM
mudkicker78
it would be better if your power on the gps is not switched, this is just my opinion, my tomtom takes like 10 minutes to load up and reach a satalite (hate tomtom) You would be fine though as long as you fuse the power lead before the acual splice concidering your gps is a computer device, any spike in voltage could fry it
Old 05-12-2010 | 07:26 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
VSS is only accessible at the PCM plugs on the pass side firewall in the engine bay.
Old 05-12-2010 | 07:39 AM
AF_HEMI's Avatar
AF_HEMI
davb, why do you want the VSS wire? If you're thinking about tapping into it, i wouldnt. Thats one wire you dont wanna potentially affect the voltages on with outside equipment
Quick Reply: Help identify plug under driver side dash please
