Lift help
Old May 12, 2010 | 11:48 PM
Dj82's Avatar
Dj82
Default Lift help
I have and 03 2500 quad cab hemi short bed. I want to lift it but I'm not sure on height. I think I want 35x12.50x20. I'm thinking 4 to 6 on lift. Any pics and suggestions would be helpful, thanks
Old May 13, 2010 | 12:53 AM
hemiguy0302's Avatar
hemiguy0302
I have a pro comp 3". I run 35x12.50s on a 17x9. Works for me. You can probably even get away with a front level kit too. If not sky jacker should have what you need.
Old May 13, 2010 | 12:04 PM
mikbimdre's Avatar
mikbimdre
i know alot of people run the fab-tech 6" lift. I just install a 3" body lift which is a much cheaper way to go. I'm going to get some 35s for it which will fit fine. really it depends on how much you want to spend and what you want to use it for.
Old May 13, 2010 | 01:20 PM
HammerZ71's Avatar
HammerZ71
Nice thing for you is with a 2500, you have a solid front axle, no having to use a sub-frame to build off of like us IFS guys. Cheaper and stronger for you...
Here is a little reading:
https://dodgeforum.com/forum/3rd-gen...uck-101-a.html
