Bumper Hitch Hole Plug
Old May 13, 2010 | 06:43 PM
Parshooter36's Avatar
Parshooter36
When I bought my truck, the center hole had been cut out. I couldn't find a plug anywhere on the web for it, so I ended up buying this.
It's not exactly what I was looking for, but it does the trick.
Old May 13, 2010 | 08:13 PM
Bent's Avatar
Bent
I'd put a bath tub drain stopper in - it'd be funny.
Old Aug 14, 2012 | 12:35 PM
jeffstoy's Avatar
jeffstoy
Default Found your plug
I took a look at my factory plug and the part numbers are molded on the under side. 5507311AB Black and 5507311AA Gray. They obviously used the same mold to make both colors. A quick search of the numbers to see if they were any good brought a dealer hit for Black at $5.35 and another dealer had Gray at $11 and change. If your'e going to order I'm sure one of the on line discount Mopar dealers can supply it at a decent price.
I've got a harder problem. The class III trailer hitch from Mopar puts a 3/4" bolt through the hole we have been discussing. The bolt head sticks out of the bumper so the original plug is replaced with a domed plug that clears the bolt. It comes with the hitch kit. I was considering an after market from Curt or Drawtite that I could get cheaper and which mount the same way and don't come with a domed plug. I've had no luck finding the number. It's probably on the bottom like the regular plug, but if you dont have it it's a dog to get it. If anybody has the oem hitch could please look at the under side of the plug for a part number. Thanks.
Old Apr 18, 2016 | 12:53 PM
pvb413's Avatar
pvb413
Default Bumper hitch hole plugs
These work great as replacements that stay in and hold up well to harsh environmental conditions.
- Black plastic plug for 3/4" diameter holes: "http://www.ebay.com/itm/141711362209"
- Chrome head plug for 3/4" diameter holes: "http://www.ebay.com/itm/131556057883"
- Black plastic plug for 1" diameter holes: "http://www.ebay.com/itm/141711430219"
- Chrome head plug for 1" diameter holes: "http://www.ebay.com/itm/131556060195"
